P0171 (Searched for an hour, still confused)
Old Apr 9, 2013 | 01:10 AM
CleanCut's Avatar
Ok so my car is throwing P0171, unmetered air, running lean and what not.
From searching, Ive seen that some people think its the solenoid, others think its the bypass valve...
My question is how do I test them to see if they're bad.
My cars symptoms are the car runs sluggish, horrible gas mileage, and I already checked around for leaks. Both o2 sensors are new and the MAF is working fine.
Thanks in advance for the help
Old Apr 9, 2013 | 01:14 AM
yellowssbolt's Avatar
Engine power reduced???
Old Apr 9, 2013 | 01:20 AM
CleanCut's Avatar
nope.. just runs pretty sluggish.. oh and i forgot to mention that when i step on it, the engine seems to take a while to slow down.. the rpms go down slower than normal in neutral
Old Apr 9, 2013 | 07:52 AM
BlackyK's Avatar
Clean your TB and tighten down all your intake hose clamps?
Old Apr 9, 2013 | 07:55 AM
mrbelvedere's Avatar
is the car stock
Old Apr 9, 2013 | 07:32 PM
CleanCut's Avatar
Car is stock and i cleaned the carbon buildup in the throttle body about 5k miles ago... also the intake pipes are tight..
Old Apr 10, 2013 | 02:46 PM
CleanCut's Avatar
Old Apr 12, 2013 | 01:52 AM
CleanCut's Avatar
More searching still Nada... Anybody?
Old Apr 29, 2013 | 01:23 AM
Nighthawk243's Avatar
When I was getting 0171, I had to take a can of carb cleaner and spray around the engine bay and listen for a change in RPM. Turns out the compressing of the phenolic spacer I put in caused unmetered air to enter at where the IM met the engine block. Spray around the vacuum hoses and near the gaskets.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dennis69
Oct 20, 2015 07:39 AM
Builttss
Oct 4, 2015 10:21 AM
Delta coupe
Sep 30, 2015 08:11 AM
dennis69
Sep 28, 2015 02:16 PM
