p0300
Old Jun 16, 2008 | 07:02 PM
Altiery54's Avatar
p0300
just threw that code and i know it has to do with my new plugs. i was tuned and dropped pulley sizes yesterday. i am running ngk's 2 steps colder gapped at .038, along with a 2.8 and 60's. what should i do?
Old Jun 16, 2008 | 07:03 PM
thatotherguy's Avatar
it's a cylinder misfire.. i might be wrong but im pretty sure thats what it is
but its im right its is basicly a bad spark plug
Old Jun 16, 2008 | 07:04 PM
BigTizzle903's Avatar
i had it. random multiple cylinder misfire. for me it was water in cylinders 1,2, and 3 causing the plugs and coils to go bad. hopefully that isnt what happened to yours.
Old Jun 16, 2008 | 07:05 PM
Altiery54's Avatar
i turned it off with my aeroforce. is that anything i shold be worried about or just one that pops up from time to time??
i drove through like 30 minutes of straight downpour yesterday. but i drove it 100 miles yesterday after that and then some today and right b4 i put it back in the garage the light popped on
Old Jun 16, 2008 | 07:06 PM
it means one or more of your spark plugs are fucked
Altiery54's Avatar
is it fine to drive or should i just leave it in the garage till i get the new plug?
Old Jun 16, 2008 | 07:08 PM
I wouldnt drive it at all until you check your plugs.. wouldnt want something serious to happen would you? dont risk it
Old Jun 16, 2008 | 07:10 PM
i'd leave it garaged. check the plugs now. pop em in and see if it goes away. if not then maybe its time to bring it to the dealer?
Altiery54's Avatar
ight. i'll check them out and see whats up with them later
Old Jun 16, 2008 | 07:12 PM
alright just take them out and check them and if they look fine put them back in and try it again and see if the CEL goes off
Old Jun 16, 2008 | 07:16 PM
Altiery54's Avatar
well i cleared the code and let it sit then started it and let it run and no code so......
it would take maybe 5 to 10 minutes for the light to come back on
ok. i'm gonna go turn it on an let it run for like 15 minutes and see how it goes from there then
Old Jun 16, 2008 | 07:19 PM
alright man good luck!
Old Jun 16, 2008 | 07:45 PM
Altiery54's Avatar
so i left the car idle for 20 mins. and know check engine light. whats going on?
Old Jun 16, 2008 | 07:47 PM
Super_SS's Avatar
ur problem is the 2 step plugs...buy 1 step colder and ull be fine...happened to me and 07 ss/sc and we switched back to the stock plugs and problem went away.I would suggest buying the zex plugs..They are 1 step colder and are much better than the ngk's.
717ssbalt
Sep 1, 2015 10:51 AM
Inferno
May 20, 2010 07:44 PM
CobaltSS_25
Nov 17, 2009 05:20 PM
kyle1853
Mar 26, 2009 07:08 PM
BlackSSnTN
Dec 27, 2007 10:22 AM
