P0420 Catalyst System Low Efficiency
My check engine light went off yesterday i was P0420 Catalyst System Low Efficiency ECM, PCM does that mean i need a new cat or has anyone had this problem before any help is appreciated thanks
i just got a downpipe off of someone on here but he said it has a magnaflow hiflow cat but i've had to had the flexpipe fixed on it already is been on my car for bout a month
aftermarket cats sometimes cause these codes when nothing is wrong, to keep the light from coming on you can tune it out with hp tuners, purchase an 02 simulator or use the sparkplug anti-fouler trick. i dont have time to explain it but do a search for it if someone doesnt explain it before i get home. but also, there is a possibility that your cat is bad and the code is legit.
importkiller
Sep 30, 2015 07:18 PM
