Painting my header/dp
Old Mar 10, 2009 | 02:29 AM
TommySSSC's Avatar
i didnt get a stainless steel or chromex covering or whatever they wanna call it. Cant i just go to autozone and some some high temp engine paint and spray like 5 coats over the header and dp? wont that help it from rusting out? Ive sprayed my brake calipers and my spark plug cover 2 years ago with high temp spray with a bunch of coats and they still shine like i just painted them.
Old Mar 10, 2009 | 02:32 AM
SlowBalt_06's Avatar
which header?
Old Mar 10, 2009 | 02:40 AM
AjSS's Avatar
Even if you use the "High Temp" paint, it will burn and smoke and come off. Either get it Jet-Hot coated, or similar, or leave it be.
Old Mar 10, 2009 | 02:50 AM
FASTL61's Avatar
yes they have one called flameproof.ive used it.and worked great.and to add was used on a DC header(civic)
Old Mar 10, 2009 | 03:06 AM
RBC's Avatar
RBC
The high temp paint will work just fine. You must first prep the surface very well. Use the recommended sand paper on the can, and sand it until the surface of your peace looks uniform and not just scratched up. Wash it dry it paint it. Wait a week or so before you install it. 99% of the people that have problems with the paint did not prep it correctly and it will chip off of burn off. Use the entire can on the header but put the coats on as directed by the instruction on the back of the can. If you let it dry long enough(that all depend on how many coats) it will get as hard as a rock. I have done the many time with much success and 0 failures. If you bang it around before the paint is completely cured well hell yea its going to chip or burn.
Old Mar 10, 2009 | 09:02 PM
TommySSSC's Avatar
thanks, this is for the zzp midlignth combo. I dont think im gonna touch the dp. I think painting the header red might add some flavor, yet again, nothing is wrong with black.
Thanks rbc, ill do what i can and then giveyou some feedback with the results. Autozone high temp engine spray paint?
Old Mar 10, 2009 | 09:06 PM
1badBlueberrySC's Avatar
These cars run too hot for just basic spray paint.
I coated mine with 1500* ceramic from VHT! Unless you paint it and bake it properly it won't last but a few minutes!
Mine started smokin almost immediately and flaked off!
Old Mar 10, 2009 | 09:10 PM
StevesBlack06's Avatar
i cleaned my Cobalt addiction DP up with a scotch brite then sprayed it with breakclean... used hi temp primer and paint and it looks bad ass. took it back off after a year and looks the same as when i put it on...
Old Mar 10, 2009 | 09:27 PM
TommySSSC's Avatar
im sensing to feel that better the prep work done, the better it will holdup
Old Mar 10, 2009 | 11:47 PM
RBC's Avatar
RBC
He is talking about high temp paint.
Get the highest temp you can get. With this its better to over do than under do. I bet you could do the autozone brand and be just fine but if you have the extra cash stick with the name brand. Get enough to do ATLEAST 3 thick coats. I prefer to do atleast 6 thin coats to reduce runs and it helps reduce drying time a tiny bit. When your painting its better to buy to much and take the rest back than to not have enough.
Old Mar 11, 2009 | 02:03 AM
tdipowered's Avatar
get it ceramic coated
Old Mar 11, 2009 | 08:14 PM
TommySSSC's Avatar
ceramic coating seems pretty expensive and i wouldnt even know where to go to get it done in columbus. ill stick to the advice rbc
Old Mar 12, 2009 | 01:19 AM
SCcobaltSS's Avatar
Jet hot coating would be the best. But if you cant get that done a simple 1500-2000 degree paint will work just fine. Prep the header real well, do not touch it with you hands after prep, prime, then paint. You will not need to bake it. It will give you curing instructions on the can. Its something like, run car for 10 minutes, let cool for 20, run for 15 minutes let cool for 30, etc..
chefhhr
Oct 26, 2015 10:36 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
riceburner
Sep 26, 2015 12:57 AM
