Piston Help..
well i bought the pistons 10-1 together with JBP triflow stage 2 cams and JBP valves spring with upgrade vavles stock size, and balance shafts ...good combo??
will be going on with the TVS down the line..
goint to have the be very carfull to controll detonation. i have used the tryflow cams (i actualy know the guy that designed the profile for the 2.2 eco, then the guy started grinding cams for jbp with his profile) and i can tell you they dont work that well with boost, however the slightly larger overlap will help bring the dynamic compression down to were it should be.
Turbo Johnny
Feb 21, 2019 09:41 AM
