Ported blower gains
http://www.zzperformance.com/grand_p...=162&catid=106
$200 ported m90 housing from zzp..
is the one i posted compatable with his internals?
Last edited by chevysalesman614; Aug 13, 2007 at 06:53 PM. Reason: Automerged Doublepost
You could look here if you want to try to do it yourself.
http://ciaz.net/forum/viewtopic.php?t=1085
I saw lower IAT2 temps, and it's a little louder.
so far, that i am aware of, no one has gained anything from this. i might be wrong, sometimes i am. so you might want to double check.
just because it lowers the iat's doesn't mean it gives you more power. it gives you the power that you already had back, in laymens terms at least.
its not cheap but but www.jbodyperformance.com does an all out port pollish and tune on the charger
I'd rather burn money then waste it on there products.
It'll be funny if i could post the same gains for a thousand dollars compared to the TS's 3K pricetag.
By the way... If the gains are good i will be able to get these adapter plates mass produced for whoever wants them.
