ported tvs supercharger??
Old Aug 13, 2011 | 01:21 PM
defo98's Avatar
I thought it was already discussed that plugging the holes in the m62 is a no no?
Old Aug 13, 2011 | 01:25 PM
ecot3c inside's Avatar
it is.
Old Aug 13, 2011 | 01:37 PM
euthanasia's Avatar
Originally Posted by ecot3c inside
porting the m62 has a few gains, very little is an understatement.
I agree very little
Before Ported SC
dynoroadracing004.mp4 video by euthanasia662 - Photobucket
After Ported SC
dynoroadracing005.mp4 video by euthanasia662 - Photobucket
Before
M62SC001.mp4 video by euthanasia662 - Photobucket
After
PortedM62SC009.mp4 video by euthanasia662 - Photobucket
Old Aug 13, 2011 | 01:38 PM
Bluelightning's Avatar
Got Bewst?
it is.
Maybe plugging it with quicksteel it is. But if it was plugged properly is there actually a downfall performance wise? I started a thread a while ago about plugging the holes and affects on performance. It was just a debate for the most part and then zoomer from ZZP chimed in and said they tested it and the car lost hp and it raised IATs. But I don't see how. I asked for actual proof but never got a response.
Old Aug 13, 2011 | 02:13 PM
WickedSS2005's Avatar
Plugging the holes is a "cosmetic" mod... It only produces more noise. I had done this to my old M62
Old Aug 13, 2011 | 02:34 PM
defo98's Avatar
eaton says you can plug them... but I also heard from zzp that it creates higher iat2's but there was no proof but also no proof to say it doesnt. Looking at euthanasias videos im probably going to get mine ported
Old Aug 13, 2011 | 02:41 PM
Sharkey's Avatar
eaton states the holes were put in to reduce noise. being an oem appication they need to meet strict NHV requirements. they also state that plugging them does not change the outlet temps or change the superchargers performance at all. this was all in the modding the m62 guide thats stickied here, and must of that info came from eaton themselves.
if eaton says it doesnt change the blowers performance, ill trust that over anyone else. they have spent more money than we could think building and developing the m62 supercharger. the engineers are far smarter and have far better lab equipment than anyone in the cobalt aftermarket.
Old Aug 13, 2011 | 02:49 PM
Got Bewst?
Ya I know eaton says it's just a nosie thing. And I want to plug mine lol. But then zoomer came in saying they tested it and the car lost hp and had higher IATs. I told him to show me proof and he vanished
Old Aug 13, 2011 | 05:37 PM
That's what Zooomer does
You can't believe everything on the internet and really, dyno-ing the same car at a different time the same day results in changes. So does the length of time on the dyno, and the settings.... Just do it
Old Aug 13, 2011 | 07:47 PM
Got Bewst?
Lol that's what I said back to him. Just need to do something better than quicksteel
Old Aug 13, 2011 | 07:51 PM
  #36
That's what I used. 20k miles later, and a new owner, it's still there
Old Aug 13, 2011 | 09:46 PM
  #37
Sharkey's Avatar
the ideal thing would be to have some aluminum plugs machined with flanges on them, and you drill and tap the blower case and screw them in using green loctite. however quick steel seems to have proven itself to work quite well. the nice thing about the design of the lsj intake is if the quicksteel was ever to fall out it cant actually get up into the motor.
Old Aug 13, 2011 | 10:21 PM
  #38
Got Bewst?
Well I read a thread a short while ago of a guys quicksteel letting go. I'm gonna get some plugs machined if I'm going to do it.
Old Aug 15, 2011 | 05:38 PM
  #39
if you plug your ports your a moron. even if you did get any gain it would be like +1tq or something ridiculously low, not worth even talking about.
Old Aug 15, 2011 | 08:11 PM
  #40
euthanasia's Avatar
Taken from the Eaton thread.
Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing
Old Aug 15, 2011 | 08:17 PM
  #41
Frew's Avatar
I plugged mine, 2 years ago, with quicksteel, just got a little louder *shrugs*
Old Aug 16, 2011 | 12:10 AM
  #42
defo98's Avatar
isnt there something else thats better then quicksteel?
Old Aug 16, 2011 | 12:41 AM
  #43
Omnigear's Avatar
weld
Old Aug 16, 2011 | 12:45 AM
  #44
Sharkey's Avatar
you cant weld it, tollerences between the rotors and case are too tight and welding it will cause distortion, causing the rotors to hit the case.
Old Aug 16, 2011 | 01:18 AM
  #45
defo98's Avatar
i remember someone using something similar to quicksteel but they said it was better I cant remember what it was though
Old Aug 16, 2011 | 01:28 AM
  #46
Omnigear's Avatar
lol welding it is better than liquid steel , he didnt ask any specifics
Old Aug 16, 2011 | 10:27 AM
  #47
Good job ecot3c inside; Yet [b]ANOTHER[\b] example of someone talking out of their ass without researching the info themselves. The ports are there for noise reduction but a tiny bit of efficiency can be regained by blocking them off.
Old Aug 16, 2011 | 10:28 AM
  #48
JB Weld is similar to Quicksteel. DO NOT USE IT THO. It has been known to fail frequently
Old Aug 16, 2011 | 12:16 PM
  #49
euthanasia's Avatar
Agree
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
goaliemo
Sep 28, 2015 01:37 PM
