Possible Intercooler Pump Upgrade (Pump Information)
Ok so class just raped my brain and I'm watching naruto while waiting for my next class so sorry for the stupid idea but.......would it be possible to have 2 heat exchanger setups with 2 pumps. With a custom endplate that would have 4 nipples on it. Have one of the pump setups go in through 1 core and out the one under it. lol kinda lost myself trying to explain it
Mr. B said this pages ago.
Get to welding and find a spot for two OEM pumps to fit.
Other one can go under the horn with a custom bracket. It's how I had mine before since I didn't have a stock IC pump bracket. I'm turbo now though...just here to learn things lol.
Ask your question about it in the appropriate forum.
This is about the Benz pump. Adding more capacity to the stock pump is something different. Honestly, you should buy one of these and try it with more flow.
what I have always wanted to see is a pulley driven pump that replaces the ac compressor. Now that would be something. there are many options if you look into marine pumps. would only need to fabricate a custom bracket. Might need to use a different design for the filler neck though to handle the additional flow and pressure.
the Mercedes pump? that's what I run on my car. Sadly I never ran the oem, so I have no comparison. I am also single pass, so my setup is all over the place in terms of comparison
