Possible new Supercharger cooling mod?
Old Jun 15, 2017 | 08:52 AM
Randomly as hell found this on facebook on a non-cobalt related page.
No idea who's car this is, the validity of installing a fan over the blower, what else is done, but thought this looked neat and figured i'd share for discussion.
Also hi guise
Old Jun 15, 2017 | 09:02 AM
Looks interesting
Old Jun 15, 2017 | 09:03 AM
In for the discussion and lol's
Old Jun 15, 2017 | 09:25 AM
advise's Avatar
Also hi guise
Attachment 10398
Hi stranger
Old Jun 15, 2017 | 09:34 AM
hey man!
Yeah I thought it was interesting, when i first saw it i didn't recognize it was an LSJ and thought it was some strange fan/leafblower-turbo thing
Then i looked deeper and thought 'hmm!' I mean it can't hurt, haha.
Old Jun 15, 2017 | 09:35 AM
jdbaugh1's Avatar
I wouldn't think that would have significant benefit at all as engine bay air is heated and the small ribs on the SC aren't really cooling fins. Also having the fan mated up against the SC that tight there isn't going to be very much airflow.
Old Jun 15, 2017 | 11:24 AM
chevygirl2006's Avatar
Seems like that would take forever
Old Jun 15, 2017 | 12:01 PM
Lolol. I doubt it does much, if anything.
Old Jun 15, 2017 | 12:04 PM
It likely adds more heat from increased engine load
Put some ice in the option b tank ��
Old Jun 15, 2017 | 12:35 PM
Staged07SS's Avatar
Administrator
Administrator
Ice in an Opt. B tank wont do anything....
Now if you have a flow through reserve tank (ie. ice box) that will work.
Old Jun 15, 2017 | 12:39 PM
Won't help cool the blower off but it helps with the temps. I did it last weekend and it lowered my iat2 15+ degrees lol
Old Jun 15, 2017 | 06:34 PM
OzzyruleZ's Avatar
Phenolic spacer makes it so the blower barely gets warmer than ambient. Also doesn't look awful like a fan right on top of it
Old Jun 15, 2017 | 07:05 PM
Does anyone besides zzp sell that? They are out of stock.
Old Jun 16, 2017 | 07:41 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by OzzyruleZ;7652329[B
]Phenolic spacer makes it so the blower barely gets warmer than ambient. [/B]Also doesn't look awful like a fan right on top of it
But its prone to causing vac leaks due to not sealing correctly in some cases.
Old Jun 16, 2017 | 08:35 AM
advise's Avatar
ive ran over 30 psi and meth thru it with good results
high tack gasket spray is your friend with the paper gaskets they give you
Old Jun 16, 2017 | 08:59 AM
jdbaugh1's Avatar
I've used both copper RTV on a bare phenolic spacer as well as the high tack spray on the paper gaskets. The high tack spray on the paper is definitely the way to go and you'll especially thank yourself when it comes time to remove it again. Yielded a good seal both ways. The steady state temperature of my blower and IM are way lower with it than without it. It takes a lot longer to heat soak sitting still too.
Old Jun 16, 2017 | 12:39 PM
Staged07SS's Avatar
Administrator
Administrator
Good to know, and that's why I said in some cases.
Old Jun 16, 2017 | 09:19 PM
ItalianJoe1's Avatar
That's a member on here, he tracks the car, and IIRC claims it lowers the temperature of the blower (not the IAT but the blower itself) by 10 degrees.
As for the phenolic spacers, I installed a set for a local guy, best single cooling mod you can do. His car is on E85 anyway but I couldn't believe how low the IAT2 temps were with just a dual pass and spacers in our south FL heat.
Old Jun 17, 2017 | 08:35 PM
Henry3959's Avatar
Waste of a good fan...
Old Jun 21, 2017 | 12:18 PM
jmix's Avatar
So does the spacer work? It seems like I've seen people argue either way. I have opt B, dual pass, and zzp HE in parallel with stock and it sucks driving my car when it's 90+ out.
Old Jun 21, 2017 | 12:22 PM
Henry3959's Avatar
What are your engine temps running?
It was 99 here yesterday. AC was great but engine temps were running much higher.
Old Jun 21, 2017 | 02:31 PM
jmix's Avatar
Engine coolant is usually around 185 or so when it's hot out. My IAT2 will be around 125-130 cruising if it's 95 or so outside.
Old Jun 21, 2017 | 04:10 PM
Henry3959's Avatar
That's a very good temp for the coolant. If you haven't done it recently, you may need to pull the Lamanova cores out and clean them.
Old Jun 21, 2017 | 04:42 PM
My cruising temp was 110-115 the other day and it was 95-100 outside.
