possible wide band problem
Old Mar 12, 2012 | 10:38 PM
Tjolley's Avatar
Okay I just did the z z performance long tube header. Catless downpipe. And a z z performance 3 inch exhaust.. I put it all on and now my wide band re 10.0 at full throttle.. I was running 11.8.. I have not changed my tune.. anyone have any ideas
Old Mar 12, 2012 | 10:43 PM
SlowBalt_06's Avatar
what was the location of the wideband on the old setup and angle?
Old Mar 12, 2012 | 10:55 PM
Tjolley's Avatar
To be honest I wasn't exactly sure... But it was a lot closer... but the afr are was almost perfect to the commanded a f r
Old Mar 13, 2012 | 03:19 AM
Bluelightning's Avatar
Got Bewst?
Wow that's wierd. You should be going leaner not richer. And thats a huge change. When I installed my long tube I went from 11.5 to 12.0. Something with the wideband would be my guess.
Old Mar 13, 2012 | 06:22 AM
Tjolley's Avatar
that would be my guess...... cuz our car stick to the command afr pretty much right...
Old Mar 13, 2012 | 09:47 AM
mrbelvedere's Avatar
take a rag and soak it in break clean and then wrap it around the sensor and see what it reads and the other thing to consider is now that you are moving alot more air through the engine you could be skipping cells on the maf and the pcm is over compensating i could be wrong it was just a thought
Old Mar 14, 2012 | 08:44 PM
Tjolley's Avatar
the brake clean is a good idea... I don't think the pcm uses the maf sensor at wide open throttle feeling... Someone correct me if I'm wrong.. From my understanding it was just the primary o 2 sensor mainly...
turbochargedss2012
Sep 20, 2023 12:17 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
