Power expectations
I't all depends upon the tune and the car. Different cars take different to the same parts. I would say you SHOULD be around 260 when all said and done. If you can run E85 without any problems then you would be more towards the top end of 260
go to the dyno section and look at peoples mods and what they have put down there are to many variables
I could use the search your right, but when I was looking for helpon the install of my Axles I sifted through 23 pages of nothing....
The search here needs to be more refined. Hell, it should have a selection for what part of the forum you want to look through. (i.e. How to, appearence, LSJ Performance tech, LNF....)
Most of the current Dynos are for LNF's. I did look to see what people were making no one really had my mods. One guy made 239 w/o pully and injectors. so I figured about another 20 off of that would be accurate so I made the thread to get others input!
20. recklessactn 261whp 228wtq Verified Mustang Dyno 42, 2.9, I, H, DP, T Graph
There are others similar as well...
when ever i search i search titles only not entire post. helps to remove the clutter some. but then again this is all dependent on people having a somewhat detailed title.
