pulley
Old Dec 25, 2007 | 02:09 PM
frdmustang92's Avatar
pulley
whats the smallest pulley i can go with out any mods like comp tune or injectors. i found a company that said i can go with there 3.10 pulley and all i have to do is run a step colder plug. how big is the stock pulley?
Old Dec 25, 2007 | 02:14 PM
Jared B's Avatar
i think it is 3.2
Old Dec 25, 2007 | 04:54 PM
WickedSS2005's Avatar
Stock pulley is 3.35"
You can safely run a 3.0 pulley and use 1 step colder plugs gapped to .040"-.042". I ran that for 6 months no issues and a friend of mine ran that setup for over a year before stage1 and 2 came out. To be a lil safe piece of mind, you could stop at 3.1". I recommend ZZP pullies and hub.
Tom
Last edited by WickedSS2005; Dec 25, 2007 at 04:54 PM. Reason: Automerged Doublepost
Old Dec 25, 2007 | 05:07 PM
hawlyns711's Avatar
if you're stock, the extra boost form a smaller pulley will just get bled off, you'll just reach 12-12.5psi faster
Old Dec 25, 2007 | 07:25 PM
Only partially true. There is a hose heading back from the bypass valve to a littel box, pull it off from the back of the box that it leads to and plug it with a screw. That will stop excess boost from bleeding off. I forgot to add that part. if you need alil more info, look up "boost bypass mod"
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
