pulley/injectors question.
Old Oct 31, 2008 | 12:49 AM
blk ss/sc 1's Avatar
I decided I wanted to get a pulley, injectors and a custom tune instead of GM stage 2. I would like to go with 2.8 pulley, do i use a stage 2 belt? And should i go with 42 njectors or 60 injectors?
Whats the best pulley to get?
To those who have something simlair to the set-up I want -- how much of a differnce will I notice?
Is there anything else I need?
Old Oct 31, 2008 | 12:52 AM
YellowBalt06's Avatar
2.8 and 60s and tune with a stage 2 GM belt should be fine
should i get differnt spark plugs?
Old Oct 31, 2008 | 12:54 AM
JimzSS's Avatar
1 step colder than stock
yeah one step colder NGK Brk7e
Old Oct 31, 2008 | 12:55 AM
ight thanks.
Old Oct 31, 2008 | 12:56 AM
lsjwannabe's Avatar
http://ottperformance.com/product_in...roducts_id=111
i would look into our stage 2 kit it comes with everything you are looking for and the tune to complete the package. Let me know if you have any questions .
JimzSS's Avatar
also autolite 3922^^^^^there you go, all in one shot
Old Oct 31, 2008 | 12:58 AM
JUICETURBOSS's Avatar
you want to go with ngk brk7e gap at .40. with a 2.8 pulley you needs 60s to run a 7000 rev limit the 42s run lien at the top.
Old Oct 31, 2008 | 01:03 AM
did u mean stage 1 kit?
also do i need the stage 2 belt for the 2.8 pulley?
Last edited by blk ss/sc 1; Oct 31, 2008 at 01:03 AM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 01:11 AM
lsjwannabe's Avatar
sorry its late lol. No our kit comes with a oversized tensioner to make up the belt slack.
as soon as we recieve it the same day or next usually, we have a few cores so turn time is good.
Last edited by lsjwannabe; Oct 31, 2008 at 01:11 AM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 01:14 AM
JimzSS's Avatar
my af's were excellent with my 2.8" and 42s...dynoed it last weekend and actually it was still fat and my auto lites are at .38" and have 11,000+ miles on them
Old Oct 31, 2008 | 01:16 AM
alright yea thats what i figured.. thats why i deleted the post haha.. well i'll probably be going with your kit... just give me a week or 2 to get some money together. thanks
what kind of gains did u get?
is it a PITA to install all of this yourself?
Last edited by blk ss/sc 1; Oct 31, 2008 at 01:16 AM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 01:21 AM
lsjwannabe's Avatar
Im not going to say this to cut down people but running a 2.8" pulley on 42lb injectors is not the safest route out there. Your injector duty cycle will be well into the 120's on a gm stage tune and close to 110 on a custom tune. also fyi injectors are only rated to 80% duty cylce so after that the injector is along for the ride and could lead to a potential lean spike or a injector failing.
Old Oct 31, 2008 | 01:24 AM
JimzSS's Avatar
^^^^very true, 60s are much safer and that is a wise statement. i am on a gm stage tune. Its fat and "safe". the car runs stronger, no doubt. But I am at the extreme safe side for a.f.s...injectors are pretty simple to install. The pulley hub takes some patients, but its not bad either. I have never done a tensioner pulley, but it can't be that hard. I say Simple and not hard with a toolbox of tools, years of wrenching, buddies that like to help out and l have learned from mistakes.
Old Oct 31, 2008 | 01:25 AM
G85 SS's Avatar
If you are going to get the 2.8 pulley, go with 60's. The 2.8 pulley on 42's will cause the car to go static.
I've got 42's on a 2.9 and am a little worried about it...About to go up to 60's with cooling mods and a tune...
Old Oct 31, 2008 | 01:58 AM
PhantomSS's Avatar
i thought the same
92% @ 6800 rpm with 42s 2.8 and 11.8 AFR under WOT
you have room to play with 42s and the 2.8 just tune it.
Old Oct 31, 2008 | 02:00 AM
do you have a 7000 rev limit
Old Oct 31, 2008 | 02:01 AM
G85 SS's Avatar
Originally Posted by PhantomSS
i thought the same
Mine are at 96% on the 42s. But I still don't like it running that lean. So when I get the money, gonna step up to the 60s alone with a progressive meth kit and a tune.
Old Oct 31, 2008 | 02:03 AM
PhantomSS's Avatar
11.8 isnt lean to me /w cooling mods but whatever works.
Old Oct 31, 2008 | 02:09 AM
G85 SS's Avatar
I don't trust it because it's already past the injector duty cycle which is 80%....And I do need cooling mods. I'd hate to see my IAT2's.....
But yes, as I said and the other guys.... 2.8 you will need to go with 60's. If you want your car to live.
Old Oct 31, 2008 | 02:12 AM
PhantomSS's Avatar
cooling mods are everything.... dont even think about power before them.
i BEAT THE EVER LIVING **** OUT OF MY ENGINE@ 11.8-12.0 AFR and it has yet to die.
then again im the ninja tuner of roflcopter
H/E is the BEST cooling mod and investment. It should have been put on from the factory. Exhaust is second. Our EGTs are ridiculous.
Sean Cummings
Jan 8, 2020 10:17 AM
Dustin24
Oct 8, 2015 09:15 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
nduchene
North East
Jul 25, 2006 10:52 AM
