Pulley Install - Stage 2 to 3
Just a quick question. I have the stage 2 and I just got the stage 3 pulley to go on it. Do I have to do anything like disconnect the battery or anything to install the new pulley. Also, is there a how-to or anything to install it. Im sure its easy, I am just not sure how to get the belt off using the tensioner. Thanks a lot. Appreciate it.
Someone has to know...
Last edited by BriantheLion26; Apr 28, 2007 at 09:05 PM. Reason: Automerged Doublepost
https://www.cobaltss.net/forums/how-guide-43/how-install-zzp-modular-pulley-your-cobalt-ss-sc-25841/
Yeah, I saw that but it didn't say what torque to tighten the bolts with either. I was just wondering if anyone has done this yet to see what they did. Thanks a lot.
anyone put the stage 3 on with the stage 2 set up?
Last edited by BriantheLion26; Apr 28, 2007 at 09:51 PM. Reason: Automerged Doublepost
Bolts get tightened to 15ft/lbs, thats from the stage 2 manual. I'd do it in a cris/cross pattern.
OK. Thanks man. I thought it was somewhere around 10-15. I'm just wondering if I should disconnect the battery while I do it so it can relearn. I never did that when I did the airbox mod. Probably wouldn't be a bad idea.
dont know if it was just the dealer i brought it too...
but my stage 2 bolts were on the TIGHT.. i believe they impacted them on there
so you might wanna look into new bolts and/or a pulley from nherbst454
patooyee
Oct 1, 2015 01:07 PM
