Pulley Swap
Pulley Swap
i need some advice, i just got the 2.9 from nate (looks/feels unreal by the way), whats the best way to take off the pulley? i took out the bolts but i couldnt get the pulley off...any advice?..everyone seems to have trouble getting the bolts out, but thats not my problem, i need to get the pulley off, by the way i am missing 1 of the 4 screws holding the pulley on, that isnt a problem is it?
you need a 15mm wrench for the belt tensioner.....put the 15mm wrench on the black part of the tension and push back towards the firewall and down and you should be able to get the belt off.......and I would probably put all 4 bolts in if it was mine....
no, how can u get the belt off, its too tight to get off...
Check this how to out: You have to use a 15mm wrench.
https://www.cobaltss.net/forums/how-guide-43/how-install-zzp-modular-pulley-your-cobalt-ss-sc-25841/
patooyee
Oct 1, 2015 01:07 PM
