Quaife LSD
Old Mar 26, 2006 | 04:10 AM
05BlackCobaltSS's Avatar
Quaife LSD
I've read a few posts on this, but can't find one post on exactly what i'm looking for.
I don't have the LSD, but am looking at buying Red/black recaro's and a quaife, which is what my question is about. From what i understand, it would be best to do clutch/flywheel/LSD all at the same time. Now how hard/mechanically inclined would you have to be to install the LSD/clutch/flywheel and how many hours would it take? (questimate please!) If not able to do by myself, could i go to any tranny shop and have them do it, and if so, about how much to install? (once again, guestimate) i priced a quaife and it's $1,445 alone so for those of you that want to order, go w/ G85!
I'm asking because i want to price exactly how much it'll be for two seats, brackets, LSD/clutch/flywheel and install. Thanks everyone!
Old Mar 26, 2006 | 04:21 AM
Badmunky's Avatar
LSD = 1,500
Clutch= 375
Fly wheel = 325
seets = 1,200
Brackets = 0. (The ones you have will work)
Install if trany parts = 1,750
Total = 5,150.00
You could to the clutch and fly wheel your self. Your looking at about a 10 hours job depending on your shop and scill level.
The diff you will need specal tools and a press to do. Along with needing to know how to take apart a trans and put it back together and still have it work. (Not as easy as it may sound)
That should be close.
Later
Old Mar 26, 2006 | 11:36 AM
cavy9psi's Avatar
well the seats you can def do yourself as far as the flywheel, clutch, LSD theres a lot to kno and find out...small things from torque specs to aligning a cluch to actually installing the LSD. and the pricing listed above by bad munkey are pretty accurate but i think gm's kit is 1,500 for the seats and the lsd cuz its a package... good luck
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
HEATON
Oct 16, 2015 07:21 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
importkiller
Sep 30, 2015 07:18 PM
