Question about smaller pulleys
Old Jul 25, 2006 | 12:39 AM
dervin3's Avatar
I have the stage 2 kit on my car and am wanting more power...how small of a pulley can I put on that will work with the stage 2 belt? and how much of a power increase could I expect out of this pulley?
Old Jul 25, 2006 | 12:42 AM
WSFrazier's Avatar
I am running a 2.5 with the stock belt. So you can pretty much go as low as you want. With my current setup, I expect 285-290whp but I have yet to get a dyno.
Old Jul 25, 2006 | 12:43 AM
vandy0419's Avatar
You can go down safely to a 2.8" pulley with the GM Stage 2 tune, this will put you around 18psi, but a smaller pulley really adds more torque than anything.
Old Jul 25, 2006 | 12:44 AM
vandy0419's Avatar
You don't have a larger idler pulley?
With him having the belt that comes with the Stage 2, he should be fine though...
dervin3's Avatar
thats awesome! now here's another question will the stage 2 injectors keep up with the 2.5? also is it just a matter of taking off the supercharger and slappin that pulley on?
Old Jul 25, 2006 | 12:45 AM
NoRemorse's Avatar
No way, he has 60# injectors
vandy0419's Avatar
He'd need a lot more to get that high of hp...he would definitely have to get a big cooling system (my current project) which will allow him to get it tuned and that will allow more timing, etc.
Old Jul 25, 2006 | 12:46 AM
WSFrazier's Avatar
Yeah I of course got the bigger injectors and a tune. The larger tensioner pulley too. But I was just staying if the only thing he was worried about was the belt, he will be fine.
Old Jul 25, 2006 | 12:47 AM
vandy0419's Avatar
+1...also, you will have to find a pulley with the same bolt pattern on it (or is the GM Stage kit a press on?), either way, it isn't as simple as slapping one on. To go for a 2.5" you need another tune, custom or INTENSE, a machined snout and as NoRemorse stated, 60# injectors.
Old Jul 25, 2006 | 12:49 AM
dervin3's Avatar
You guys must have misunderstood me...I mean how small can I go without a tensioner pulley? the 2.8 as someone said earlier? plus just how small can I go with stage 2 injectors. All I'm wanting to basically do is keep it at stage 2 but with a smaller pulley as the only difference.
NoRemorse's Avatar
Well, if you want something easy, pulleyboys make a 2.8" pulley ring that fits the GM hub.
Otherwise, I have a ZZP 2.6" pulley that requires no machining.. it is yet to be out on tho bc i havn't gotten my injectors yet!
WSFrazier's Avatar
You can get the ZZP 2.6" without machining the snout. You would also need a hub too, the ring won't bolt up with the GM one. If you just want a little more power, get the 2.8" ring. That is a direct bolt on with the GM hub and you can also keep your injectors, tune, and belt.
Old Jul 25, 2006 | 12:57 AM
dervin3's Avatar
Thanks everyone for your input...I've decided this pulleyboys 2.8 ring is exactly what I'm looking for. So when I get this thing, all I have to do is take the belt off and bolt on this new 2.8 ring?
Old Jul 25, 2006 | 07:43 AM
cds00bsmg's Avatar
precisely.....
You can also use the Mace (I think thats the brand) 2.79" pulley that is running around on ebay for about $65. That will bolt up directly to the GM hub as well.
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
