Question For All you 2.9 users with sgt 2
I tried to search this but the results were overwhelming i couldnt find anything.
What is your boost gains going from the stg 2 pulley to nates 2.9?
My car only has 3500kms on it and right now without my 2.9 (its in the mail) iam getting anywhere from 13.05 to 15.2 psi from 1st to top of 3rd.
Also i think my boost is low because if i punch it in 1st or second iam only seeing around 13.5psi, top of 3rd iam getting around 15 though...
Right now with it cold out it hits about 16.25ish (tic past 15). I wouldn't even try to watch it in first, its way too short. I had mine on for a while, a trip to the track as well. Your elevation can play a roll in your boost too, plus the gauge isn't the most accurate in the world either. You should gain around 1 psi'ish over the stage 2 pulley.
Gain varies with elevation. At sea level it's about 1 PSI per .1 inch reduction in pulley size, assuming you don't change anything else. Where I live, at 5,000 feet, I only saw a 2.5 PSI increase instead of the full 3 PSI (I started at 10 PSI and Stage 2 bumped it up to 12.5). I'd vote for you getting a full PSI gain out of it if you're hitting 15 in third.
Oh, and first gear never attains full boost, my car is fine and it does the same thing. Something to do with the boost bypass valve I believe (not 100% sure, someone else who knows please verify).
Oh yeah! Elevation does play a part in it as well.
Im at 1600ft in Saskatoon, and with Nates 2.9 I see depending on weather 16psi -16.5psi on my hpt. The gauge so far is accurate on mine showing about a needle over 110kpa ( about 112 ish)
It is worth noting - I don't know how the gauges get their reading, but if it measures the psi based off ambient, then even at 2500 ft you should still read the same PSI as at 0 ft.
Hope that helps
at higher elevations the air is thinner. which is why athletes do high elevation training. and is why helicoptors cannot fly that high. and sea level is where air the thickest. i can run 3miles in cali at about 19-20min and in idaho i run it in 20 to maybe 21
