quick question on uego install and wiring
Old Jun 7, 2009 | 07:36 PM
06cobalt racer's Avatar
i am wanting to put in my uego gauge. my question is, how did everyone run the wires for the gauge? what fuse did you tap into? how did you run the wires to the sensor? pics will be good too.
Old Jun 7, 2009 | 07:40 PM
Cefaln452's Avatar
tap your accessory to your windsheild wipers...
Old Jun 7, 2009 | 08:05 PM
blownredSS's Avatar
Stock boost gauge for power, used a self tapping screw into the a-pillar for ground. There is a hole in the firewall just above the clutch, pop out the rubber grommet and feed it through. There is a how to on installing a wideband, pics are with it.
Old Jun 8, 2009 | 10:43 AM
are you refering to this one?
https://www.cobaltss.net/forums/show...ighlight=gauge
if so that isnt a uego and the pics dont work
Old Jun 8, 2009 | 07:51 PM
blownredSS's Avatar
No that wasn't it. I'll see if I can find it.
OBZ was the OP of the how to, I couldn't find it.
Old Jun 9, 2009 | 11:31 AM
anyone else have any insite? wanting to do it this week.
Old Jun 9, 2009 | 09:10 PM
Gene Culley's Avatar
Talking
I'm going to be doing the same thing soon. From reading a lot in the how-to's, just get a littelfuse "add a circuit" and be done with it.
Got it from this thread..
https://www.cobaltss.net/forums/how-guide-43/how-install-gauges-your-2-2-2-4-switched-source-114611/
Here is the littelfuse thing...
http://www.parts-express.com/pe/show...number=071-580
Last edited by Gene Culley; Jun 9, 2009 at 09:10 PM. Reason: Automerged Doublepost
Old Jun 9, 2009 | 09:56 PM
rico's Avatar
runn it off the booost gauge
Old Jun 10, 2009 | 04:27 PM
are you talking about tapping into the fuse?
i am using the steering bezel pod. where is the power wire for the boost gaguge? will i need to remove the a-pillar?
also i will be installing the interceptor gauge. can i tap the uego and interceptor power wires into the boost gauge power wire?
Last edited by 06cobalt racer; Jun 10, 2009 at 04:28 PM. Reason: Automerged Doublepost
Old Jun 10, 2009 | 05:01 PM
blownredSS's Avatar
remove gauge pod, pink wire going to stock boost gauge is power, I used both on the one power wire, works fine.
Old Jun 10, 2009 | 05:37 PM
Mattman6's Avatar
you can also tap the rear cig lighter if you want. Thats what i did and it works good, comes on when the key is turned over.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
