R u underboosting and you wonder why?
Old Sep 8, 2006 | 09:19 PM
*TRIX*'s Avatar
very simple thread
i have a cobalt ss
i had a 2.8 inch pulley
and i have a cobalt addict tune and the boost bypass off cause I thought I didnt need it
and when i dropped to the 2.7 i had problems
i kept loosing boost and i couldnt figure it out
got stg 2 belt still loosing boost
checked entire engine bay for leaks and took supercharger off
no leaks
I then thought to myself lemme try to the boost bypass mod . i tried it and i had full boost again
i took the bleeder/bypass off and looked at the internals and all the platic and everything was cracked and bent and broken
sooo if anyones having boost problems just throw the bypass mod back on
thought id input my 2 cents
Old Sep 8, 2006 | 09:20 PM
04 wrx's Avatar
thanks man
Old Sep 8, 2006 | 09:21 PM
*TRIX*'s Avatar
Originally Posted by 04 wrx
thanks man
anytime? but do you have a cobalt?
Old Sep 8, 2006 | 09:22 PM
Matty's Avatar
Where did the boost go from- down to? Did it keep dropping or finally level off?
Old Sep 8, 2006 | 09:24 PM
*TRIX*'s Avatar
it would level off at some point like the computer was fixing it but it wasnt
the boost would actually flutter out of it kinda sounding like a wastegate
ooo and it was from 17 to 10
it wouldnt peak after i blew it out
Old Sep 8, 2006 | 09:31 PM
Yodair8's Avatar
I just barely posted about why I'm getting such crappy boost, maybe this is my answer
Old Sep 8, 2006 | 09:47 PM
BlueSS-supercharged's Avatar
so your saying we should plug back in our boost bypass mod?? is that only because you have a tune or?
Old Sep 8, 2006 | 11:31 PM
OBSSSD's Avatar
If you get the car tuned properly then boost management is completely disabled and there's no need for the bypass mod. It is very easy with HPTuners
Old Sep 8, 2006 | 11:36 PM
distillion's Avatar
^^ something i plan on doin, just dont know wat to do about first gear...
Old Sep 9, 2006 | 08:07 AM
*TRIX*'s Avatar
not trying to dick but i already said that i had the tune and i was holding boost and then when i went to the 2.7 that i blew the internals out so i had to go back to using the boost bypass mod
Old Sep 9, 2006 | 08:08 AM
*TRIX*'s Avatar
oo and go full boost
if you can drive which i think everyone on here can by now just learn how to use the power
Old Sep 9, 2006 | 08:20 AM
distillion's Avatar
ya, i have cabs, solid motor mount and im lowered, i just may do what u said
Old Sep 9, 2006 | 08:59 AM
*TRIX*'s Avatar
lemme tell you i have no motor mounts or anything and my car feels amazing with full boost in first gear
ooo and back to the thread
bump lol
Old Sep 12, 2006 | 08:43 AM
06blackg85ss's Avatar
damn you mike and your full boost in first... well now that my car actually gets traction I"m changing it tonight to see how much I can push and still get traction... but I'm also switching to the 2.5 so lets see how that goes..
Old Sep 12, 2006 | 08:46 AM
*TRIX*'s Avatar
you better ******* watch your timing and all your ratios your pushing it man
Old Sep 12, 2006 | 08:51 AM
R33P3R007's Avatar
360 L337 User
the boost bypass mod totally ***** with your a/f. Yes. I gained 4 hp and 5 or 6 tq. but it made my a/f look like /\/\/\/\/\/\/\/\/\/\ during the entire pull on the dyno.
I STILL would not reccomend doing the bypass. Just get hptuners. and compensate for it.
Old Sep 12, 2006 | 08:52 AM
hey thats what I do best... leveled out my AFR to around 12.2 so thats all good brought the timing back down to 24 deg... and running a 70%meth/30%water setup so no detonation.... hitting the track sunday and dyno oct 7th.... lets see what she can do...
oh yeah addin a little nitro to the mix for sunday... fingers crossed she don't explode (only using lik 8 oz to 1.5 gallons should be ok) I hope
Old Sep 12, 2006 | 08:53 AM
he did... the diapragm in the bypass broke and was bleed boost off (he has a hp tune on a car)
Old Sep 12, 2006 | 09:12 AM
BLKSS's Avatar
that wrx guy got banned.
Old Sep 12, 2006 | 09:33 AM
That was quick
droppindboost
Jun 27, 2015 09:30 PM
Turbo Johnny
Jun 27, 2015 09:15 PM
damastah
May 23, 2013 11:29 AM
rukkee
Sep 21, 2011 05:49 PM
