Random Misfire
Old Jun 22, 2010 | 05:39 PM
JAYNO20's Avatar
Originally Posted by mexi_loco
I don't think so. I believe 1-step colder means it will fire at an earlier degree than a n/a engine because more air is coming into the engine. Or something like that. It really has nothing to do helping the engine run cooler.
hmmm... so I shouldn't be using one step colder plugs? I thought they helped with engine heat too, but if that's wrong then maybe they are not helping with my problem...
Old Jun 22, 2010 | 05:46 PM
Redefined1's Avatar
If you use 1 step colder plugs it helps prevent predetonation. The only real diff in a colder plug is that it doesn't hold as much heat. Running a really hot plug will cause alot of pre det. found this on another site.
you absolutely should be running 1 step colder.
Last edited by Redefined1; Jun 22, 2010 at 05:46 PM. Reason: Automerged Doublepost
Old Jun 22, 2010 | 05:49 PM
redcobalt07's Avatar
nice
Old Jun 22, 2010 | 07:31 PM
ziggity's Avatar
When I got my OTTP stage kit it ran way too rich ... are you getting any other codes?
Old Jun 22, 2010 | 07:46 PM
JAYNO20's Avatar
No, that's all that's showing up on my Interceptor.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
jmelton327
Sep 26, 2015 10:04 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
