random misfire in cyc
Old Jan 13, 2010 | 05:32 PM
Fonzi1289's Avatar
K well that's a lil bettr
Old Jan 13, 2010 | 05:39 PM
raptors_67's Avatar
You'll get misfire codes from running rich at idle. Increasing RPM at idle slightly to help the larger injectors fire more precisely and correcting VE tables was the cure in case.
Old Jan 13, 2010 | 08:14 PM
SSfamilywagon's Avatar
Did you check your intake? A buddy here had the same prob and his intake was causing it. Maybe you have a leak
Old Jan 13, 2010 | 10:35 PM
Fonzi1289's Avatar
Hmm I will check that. And hey ss is it normal to have oil in the intake mani? When I took it off o check everything today there was oil in the mani.
Old Jan 13, 2010 | 10:39 PM
No there should be no oil in the intake manifold at all. Not sure how thats happening.
Old Jan 14, 2010 | 12:47 PM
383_Stroker's Avatar
How many miles are on it, how many since you pulled the intake off?
The crankcase breather is hooked to the intake tube, so if you have any blow-by it will get oil in the intake.
Old Jan 14, 2010 | 01:18 PM
Fonzi1289's Avatar
Just put it on.. and took it off two days after to check for leaks.
And what do u mean if i have any blowby?
MP Cobalt's Avatar
Also will get that code if your running a lightweight flywheel
Old Jan 15, 2010 | 01:02 AM
Winkdogydog101's Avatar
going
going 2.6 and e85 and gunna hopefully be done with this bullshit
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
jmelton327
Sep 26, 2015 10:04 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
