Random Misfire P0300
So, I discovered a Vacuum leak today, and that it caused a Random Misfire Code (P0300), So i removed the coil packs and plugs, Cylinders 2 & 4 Were flooded, and plugs were not firing.
I am running 2 step colders, Mods are:
2.7"
60#
Dual Pass B
Stage 3 Heat Exchanger
Exhaust and all supporting:
Should I just run OEM plugs, or Step 1's...
I threw the P0300, P0171 (System Too Lean, Bank 1), P0036 (H02S Heater Control Circuit, Bank 1, Sensor 2)
2.7"
60#
Dual Pass B
run 1 step colder gap at .030 and stay away from the platinum **** plugs as for the 02 codes I got them with a parts store o2 try a genuine gm part
and post problems in the problems and service section
Sean Cummings
Mar 9, 2018 12:26 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
