rattling noise at idle
Old Jul 24, 2011 | 04:14 PM
schinkelm's Avatar
Okay Ive searched and searched and i cant get any kind of answer for this problem, I have an 07 lsj with 37k mi on it and every once in a while i get a rattling noise that sounds like its coming from the head at idle, if i rev it the sound will go away and the car idles fine even when it is ratttling.. The rattling only happens maybe once every 10 times i drive the car. The only mods i have are an airbox mod, and i switched to NGK bkr7e plugs gapped to .035.. Im kinda at a loss in which direction i need to go to fix this problem, any suggestions would be apperciated...
Thanks,
MIKE
Old Jul 24, 2011 | 05:12 PM
rivaladore's Avatar
Timing chain tensioner most likely. There is a revised one that you should put in your car. The original ones are known to fail. Crate engine depot sells them and takes maybe 10 minutes to install
Old Jul 30, 2011 | 11:29 PM
schinkelm's Avatar
Alright thanks I'll look into getting one here pretty soon
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
