Rebuilding head. Need advice on parts.
07 LSJ with 65k miles.
long story short the intake vavles got bent after bumping the starter for about a second. When switching to the new style tensioner, don't let anyone tell you to just remove the old one and pop the new one in. Removing the tensioner gives the chain enough slack to droop off the crank sprocket somewhat. You need to remove the valve cover and use a zip tie to keep tension on the chain BEFORE you remove the old tensioner, otherwise it will skip timing. You should also crank the engine over by hand afterwards. People who have had success without doing this were extremely lucky. I shouldn't have listened to a lot of the posts made here on this subject.
This is what I plan on replacing aside from valves and valve guides.
Here is what I know I will definitely replace:
head gasket kit
Cylinder Head Gasket Kit Saturn Ion 2.0 LSJ 2004 - 2007 12601810
x16 lifters
Ecotec Lifter/ Adjuster 24100005 replaced by 12572638
camshaft position sensor housing seal - 12597644
front cam seal - 12578146
crank pulley bolt
Ecotec Balancer Bolt 11589123
timing chain
Chain LSJ Camshaft Timing 24461834
Front engine cover gasket
Ecotec Front Cover Gasket 24435052
front main seal
Ecotec Timing Cover Seal 12584041
Not sure if these items should be replaced:
valve keepers?
Ecotec Valve Keepers (Key) 90354648
valve cover gasket?
Ecotec LSJ 2.0 Valve Cover Gasket 90537687
Also let me know if I missed anything. Thanks!
head gasket kit
x16 lifters
crank pulley bolt
timing chain
front main seal
valve keepers?
valve cover gasket?
You don't need to replace the blower gasket unless it looks damaged. If you're like me, and like new gaskets when building something it wont hurt to replace it.
While you're at it, I would install upgraded valvesprings as well. If I was in your position, I would. Might pay off in the future if you ever decide to increase your rev limiter.
I have no intentions of making more than stock power without drivetrain modifications, and I don't plan on beefing up the trans. Have there been any problems with the stock springs on stock engines?
Need
head gasket kit
dont need unless yours are giving you problems
x16 lifters
dont need
wtf is this dont need
need
crank pulley bolt
need
timing chain
dont need stocker os o-ringed
dont need relube reuse
front main seal
dont need
valve keepers?
need
valve cover gasket?
head gasket kit
x16 lifters
dont need
need
crank pulley bolt
need
timing chain
front main seal
dont need
valve keepers?
need
valve cover gasket?
TheSandMan
09-20-2015 06:02 AM
jcalvin1126
09-11-2015 10:24 AM
