Removing stock pulley
Ok guys, so i have the ZZP tool to remove the pulley, but i was wondering is the best way to get at the pulley to just remove the supercharger from the car? Thank you for the help
It is hard to remove it in place; the Nates tool works very well but still a pita. Take the s/c off leave it in the freezer over nite, in the a.m. quickly warm up the pulley with a propane torch and pull...
YOu are good then. Some of the pulley hubs are brutal to install. I now use a Snap On powersteering puller, and to put the pulley hub on, same thing with the blower in the freezer, and the hub in boiling water, and install. The Nates hubs i prefer go on very snug, the OTTP go on hard , will never come off, and the GM hubs are (relatively) easy...once you got the hub on, you can swap easy...
z28addiction
09-28-2015 12:03 AM
