Removing stock pulley
Old 02-12-2010, 07:05 PM
laughrun's Avatar
Ok guys, so i have the ZZP tool to remove the pulley, but i was wondering is the best way to get at the pulley to just remove the supercharger from the car? Thank you for the help
Old 02-12-2010, 07:16 PM
slowswap's Avatar
I would imagine that would be a lot easier.
Old 02-12-2010, 08:09 PM
laughrun's Avatar
is there an easier/quicker way?
Old 02-13-2010, 09:50 AM
laughrun's Avatar
anyone have some input?
Old 02-13-2010, 09:54 AM
shadowfaxss's Avatar
Removing the supercharger is the prefered way to take the stock pulley off.
qwikredline's Avatar
It is hard to remove it in place; the Nates tool works very well but still a pita. Take the s/c off leave it in the freezer over nite, in the a.m. quickly warm up the pulley with a propane torch and pull...
Old 02-13-2010, 02:16 PM
laughrun's Avatar
thats what i thought.. thanks!
Old 02-13-2010, 05:02 PM
YOu are good then. Some of the pulley hubs are brutal to install. I now use a Snap On powersteering puller, and to put the pulley hub on, same thing with the blower in the freezer, and the hub in boiling water, and install. The Nates hubs i prefer go on very snug, the OTTP go on hard , will never come off, and the GM hubs are (relatively) easy...once you got the hub on, you can swap easy...
Old 02-13-2010, 10:06 PM
YzRider452's Avatar
Quick question. I have a stage 2 hub, whats the best way to get that off?
Old 02-14-2010, 12:01 AM
why remove it? see post #6 substitute hub for pulley.
Old 02-16-2010, 02:06 PM
YzRider452's Avatar
Gotcha, wasnt sure if that would work. But ill give it a shot.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
SlowSaturn
09-28-2015 11:03 AM
z28addiction
09-28-2015 12:03 AM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: Removing stock pulley
