rev limiter?
Old Oct 11, 2010 | 04:25 PM
G11's Avatar
G11
rev limiter?
so i was driving to school a few days ago and as i was coming up the on ramp i saw there was a semi in the merge lane. i got on it a little bit and as i hit 4k rpm in 2nd it felt like i hit a rev limiter...so i backed of and hit the gas again. Then it did it again as i got up to 5k rpm...
anyone know what that could of been? i haven't had this happen to me before and everyone i have asked so far doesn't know
Old Oct 11, 2010 | 04:28 PM
AngelTiger82's Avatar
Do you have a cold air intake ? That's happens to me when my air filter gets wet.
Old Oct 11, 2010 | 04:30 PM
scotch89's Avatar
would that do something with the bypass? it not working right or something???
Old Oct 11, 2010 | 04:31 PM
Pyros777's Avatar
Do you still have e-85 in the tank?
You can't run e-85 unless you actually get tuned for it. It was a really bad idea mixing 93 and e-85. Please go back to 93 and try again.
Old Oct 11, 2010 | 04:58 PM
G11's Avatar
G11
no i have just premium in my car now...i only do that on dyno days and when i go to the track
that could be possible cuz it rained like crazy that day before i went to school
Old Oct 11, 2010 | 05:05 PM
Frew's Avatar
Ya that's it pull the maf out and clean it with maf cleaner.
Old Oct 11, 2010 | 05:23 PM
Yup that happens to me when it rains crazy. Jusf dry your filter n do what the other guy said clean the maf. Usually when this happens I shift no higher than 3000 rpm and watch my speed and don't gun it till I get home and let it dry off.
Old Oct 11, 2010 | 05:25 PM
Staged07SS's Avatar
Administrator
Administrator
Sounds like spark blow out. What are your plugs gapped at ??
Old Oct 11, 2010 | 05:27 PM
ecot3c inside's Avatar
sounds like a fuel problem. I had that same thing happen to me when I had a pump tune with e85, try easing into the throttle, If it doesn't happen it's either you still have e in your tank or a new fueling issue.
Old Oct 11, 2010 | 05:40 PM
06arrivalSC's Avatar
Any codes? I was having similar issues for a while, it was like a 'buck' or strong 'hiccup' around 5500 rpms is the best way i could describe it, after a while i noticed in my interceptor a MAF code, cleaned the MAF, deleted the code from the PCM cuz it kept coming back, and she runs great again
Old Oct 11, 2010 | 05:41 PM
that's not it. He's talking about the sound and the lack of power as if you hit the rev limiter.
Old Oct 11, 2010 | 05:43 PM
Hmmm, ok i know exactly what he means now then, i just didnt know if he was 'having trouble' describing the way it sounded/felt cuz i know i never knew how to explain my issue, just had to be in the car to feel it to know what i meant
Old Oct 11, 2010 | 05:44 PM
at least that's what hitting the rev limiter feels and sounds like... he said "like hitting the rev limiter" so I assume.
Old Oct 11, 2010 | 05:48 PM
Yea ive done that twice, once in my buddies ss/sc a few years ago and once in mine, missed 3rd and was back on it for a second and yea, fail lol i usually never miss my favorite 2-3 though lol
Old Oct 11, 2010 | 06:27 PM
Pyros777's Avatar
Well, a misfire could cause a sudden bucking, as if you hit the rev limiter.
If I were in your shoes I'd start off with the simple stuff like cleaning the MAF and inspecting your plugs. If they seem fine, and the symptoms continue, I'd look into the possibility of one of your injectors crapping out.
Old Oct 11, 2010 | 07:23 PM
G11's Avatar
G11
i almost wanna say it was my filter was wet and i need to clean my maf...i will check my plugs too
it hasn't happened again since that day so it could of been those two things
as far as it feeling it feels like a hick up but sounds like a rev limiter...so both kinda right lol
Old Oct 12, 2010 | 12:40 AM
Yea mine was a weird feeling, it would 'buck', sounded kinda like a sudden spike/blip of the revs, different than a limiter but almost like i misshifted or somethin retarded, and it would jerk forward and back and by that time i would be off the throttle, i had the plugs out like 3 times, changed them once, gapped them differently twice, cleaned the MAF then noticed the code, deleted it and all good, just do a series of things to make sure everythings all good, check the plugs, gappings, clean the MAF, simple stuff and see what happens. I have a hydro/nylon shield/sleeve that fits over the air filter to help prevent sucking air up in the intake too, it couldnt hurt to look into one of these
Old Oct 13, 2010 | 12:35 AM
G11's Avatar
G11
well i have a k&n dry sleeve on it
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
