rough idle
Old Mar 16, 2013 | 11:36 AM
red_bolt_06's Avatar
rough idle
I was just wondering if any one else has had a problem with
there lsj in the rain.. every time it rains mine wants to idle rough
and when your accelerating it jerks and shakes and
most of time won't go past 3k rpms.. I've checked for
vac leaks and the intake, I thought maybe the filter was
getting damp but that's not the case cause I don't see where water
would be getting on the filter.. any help would be great cause
it's aggravating
Old Mar 16, 2013 | 11:40 AM
turbosmart4's Avatar
Maf sensor maybe? Or evap solenoid going bad
Old Mar 16, 2013 | 12:05 PM
where's the evap solenoid at them
Old Mar 16, 2013 | 01:28 PM
mrbelvedere's Avatar
post in problems and service if you are having problems in the future
your maf is more then likely wet get maf cleaner and see if it fixes the problem if it does then get a hydro shield for your air filter
Old Mar 18, 2013 | 05:25 PM
what's a hydro shield
Old Mar 18, 2013 | 05:28 PM
574's Avatar
574
Google dat ****. You need a hydro sheild if your have a CAI and your driving in the rain.
Old Mar 18, 2013 | 05:43 PM
I believe TTR sells hydroshields for 30 dollars.....
Old Mar 18, 2013 | 05:54 PM
08G5GT2.4L's Avatar
What tpye of air intake and filter do you have? Stock? aftermarket?
Aftermarket dryflow filters are notorious for getting wet and letting water through to get on the MAF causing rough idle and driveability problems in the rain.
Clean the MAF and switch to a oiled filter like a K&N, or get a hydroshield.
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Sep 28, 2015 02:46 PM
