Running EXTREMELY lean
Old Sep 20, 2011 | 10:01 PM
mscobaltss's Avatar
Exclamation Running EXTREMELY lean
Hello, I recently tuned my 2006 SS/SC. I tuned the car 2 weeks ago and it was running amazing, besides the clutch starting to fade. Well a few days ago the car started running like crap. VERY VERY lean. if i go passed half throttle the car bogs and back fires. And today the car pretty much didnt want to run. I tried changing the MAF and MAP sensor and nothing changed. I am going to try to change the fuel filter, in the hopes it is clogged. The only thing i changed besides the tune is the spark plugs, cat removal, and i used fuel injector cleaner.
Car mods are 3" pulley, exhaust and injen CAI. I am running NGK temp 7 iridium plugs. Gap is ~31
Its weird cause the car ran great before and after the tune. Then 2 weeks later, it doesnt. If anyone has had a similar problem LMK.
Thanks
Old Sep 20, 2011 | 10:06 PM
mrbelvedere's Avatar
whats the afr
Old Sep 20, 2011 | 10:10 PM
Ch1ck3n's Avatar
Check your fuel rail pressure.
Old Sep 20, 2011 | 11:02 PM
mscobaltss's Avatar
Originally Posted by mrbelvedere
whats the afr
My fuel trims are at 20+% both LT and ST
Gonna have to check if i have a gauge for that
Old Sep 20, 2011 | 11:05 PM
ecot3c inside's Avatar
what was your coolant temp? I know when mine first starts up and I go to take of it dips lean when I give it gas if I don't warm it up.
Old Sep 21, 2011 | 12:47 AM
mscobaltss's Avatar
My coolant temps are normal. My car is lean all the time. Cold, warm, now it barely runs and starts. All the plugs are white. Tryna figure out what could have gone wrong two weeks after the tune.
Old Sep 21, 2011 | 09:14 AM
richen it up
Old Sep 21, 2011 | 11:23 AM
mscobaltss's Avatar
richen it up
If the car was running good before, and after the tune for 2 weeks I would say it's more mechanical. Tuning a car with a mechanical problem doesnt fix the problem.
Old Sep 21, 2011 | 02:43 PM
i wouldent say that mine went super rich after i had it tuned and there was nothing wrong with the car mechanicaly what so ever no vac leaks and it did great on a leak down check the only thing that changed was the weather
Old Sep 21, 2011 | 03:01 PM
Whitnith's Avatar
You're going to run leaner in cold weather, if you were tuned in warm weather and vice versa. I've already switched over to my winter tune, since I've been drag racing at night in 50 degree temps and don't want to go boom.
Old Sep 22, 2011 | 12:31 PM
mscobaltss's Avatar
I checked the fuel pressure at the rail and its 22psi. Now i have to figure out if its the regulator or the pump.
Old Sep 22, 2011 | 12:32 PM
check it before the filter if u can
Old Sep 22, 2011 | 12:47 PM
BlueTurbo's Avatar
I haven't seen too many regulators go bad that way. I'd suspect pump.
Old Sep 22, 2011 | 12:57 PM
06SS ALL DAY's Avatar
You melted your cat
Old Sep 23, 2011 | 02:00 PM
mscobaltss's Avatar
Originally Posted by 06SS ALL DAY
You melted your cat
There is no cat.
Old Sep 23, 2011 | 02:08 PM
Chevycobaltss3's Avatar
If ure car runs great for two weeks and all of a sudden like ****. Then either there was a drastic elevation change or temp change. Or mechanically wise a bad 02 a intake leak after the maf which is more reasonablw
Lol fuel rail pressure should be 45-60
Last edited by Chevycobaltss3; Sep 23, 2011 at 02:08 PM. Reason: Automerged Doublepost
Old Sep 23, 2011 | 03:36 PM
meow meow meow meow
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
