Running EXTREMELY lean
Hello, I recently tuned my 2006 SS/SC. I tuned the car 2 weeks ago and it was running amazing, besides the clutch starting to fade. Well a few days ago the car started running like crap. VERY VERY lean. if i go passed half throttle the car bogs and back fires. And today the car pretty much didnt want to run. I tried changing the MAF and MAP sensor and nothing changed. I am going to try to change the fuel filter, in the hopes it is clogged. The only thing i changed besides the tune is the spark plugs, cat removal, and i used fuel injector cleaner.
Car mods are 3" pulley, exhaust and injen CAI. I am running NGK temp 7 iridium plugs. Gap is ~31
Its weird cause the car ran great before and after the tune. Then 2 weeks later, it doesnt. If anyone has had a similar problem LMK.
Thanks
Thanks
My coolant temps are normal. My car is lean all the time. Cold, warm, now it barely runs and starts. All the plugs are white. Tryna figure out what could have gone wrong two weeks after the tune.
i wouldent say that mine went super rich after i had it tuned and there was nothing wrong with the car mechanicaly what so ever no vac leaks and it did great on a leak down check the only thing that changed was the weather
You're going to run leaner in cold weather, if you were tuned in warm weather and vice versa. I've already switched over to my winter tune, since I've been drag racing at night in 50 degree temps and don't want to go boom.
If ure car runs great for two weeks and all of a sudden like ****. Then either there was a drastic elevation change or temp change. Or mechanically wise a bad 02 a intake leak after the maf which is more reasonablw
Lol fuel rail pressure should be 45-60
Last edited by Chevycobaltss3; Sep 23, 2011 at 02:08 PM. Reason: Automerged Doublepost
