Running Hot
Old May 30, 2010 | 10:48 PM
troyss's Avatar
Running Hot
Another damn thread again today. For a few days now my car seemed to be running hot. I was always at 180-190, but now I'm reaching into the 200's with ease. What can this be? Thermostat maybe? If so where are they located on and lsj motor? Thanks again
Old May 30, 2010 | 10:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
its not overheating. don't worry. low 200* temps are normal.
Old May 30, 2010 | 10:51 PM
troyss's Avatar
It reaches 225 then cool's down. I never had it that high before so it's kinda worrying me
Old May 30, 2010 | 10:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
how many miles do you have on the car?
troyss's Avatar
38,000
Old May 30, 2010 | 10:55 PM
BLAZIN07SS's Avatar
I'm too JDM for you
shouldn't be having any cooling system issues at that mileage. my car with stock fan settings used to get up to 215* easy. but if the car kicks on the fans and cools it down you shouldn't have anything to worry about. or whenever you see it heating up, turn on the AC. the fans should turn on immediately and cool it down
Old May 30, 2010 | 11:00 PM
troyss's Avatar
See that's what I thought. I used to do that all the time last year and it worked and about a few months ago I broke my AC condenser and I replaced it. I tried turning the AC on last night and didn't do nothing, didn't hear any fans kick on or nothing. I haven't got any freon in it yet but when I broke the AC condenser there were green **** leaking out. just throwing that out there.
Old May 30, 2010 | 11:04 PM
BLAZIN07SS's Avatar
I'm too JDM for you
well yeah the green stuff is freon. the compressor is not going to want to kick on without sufficient pressure in the system but i don't think that should stop the fans from kicking on
Old May 30, 2010 | 11:06 PM
troyss's Avatar
Exactly what I was thinking. Is there thermostats on these motor's? However you been a big help and thanks man
Old May 30, 2010 | 11:10 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yeah there are. fkn PITA to change the thermostats. lol. and no problem at all. where are you located in florida?
Old May 30, 2010 | 11:11 PM
troyss's Avatar
I live in Nebraska but used to live in ft.Myers, Do you know where the ther. is located?
Old May 30, 2010 | 11:17 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yep. item 307
http://www.crateenginedepot.com/pdfs...nd_Cooling.pdf
Old May 30, 2010 | 11:21 PM
troyss's Avatar
****. Is that by the fuse box? I don't need to take all that stuff off do I lol?
Old May 30, 2010 | 11:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you don't need to take it off from what i remember. its still a PITA either way. lol
Old May 30, 2010 | 11:33 PM
troyss's Avatar
Ok thanks
Old May 31, 2010 | 12:54 AM
Erick161's Avatar
mine just finally reached over 200degrees (that ive noticed) while at the track. It got as high as 215 while waiting in line, creeping up. Hasnt ever done that on the street, and it only did it once while at the track. Temps stayed around 180 the remainder of the runs.
Old May 31, 2010 | 01:21 AM
kenhebe's Avatar
You have nothing to worry about. Our cooling fans do not kick on until the water temp hits 225. It is a pressurized system so it can take higher temps. If your AC had freon in it, then the AC fan would work and keep it running no warmer than 190
Old May 31, 2010 | 01:30 AM
Billig ss/sc's Avatar
If your coolant temps starting hitting 200*+, the quickest, easiest way to cool it down is by cranking the heat on. It might sound stupid, but it'll cool the car down a lot quicker than basically anything else. If you have the Coolant setting up on the DIC and turn on the heat, you can literally watch the temps drop. It might suck on a summer day, but I'd rather be a little hot for a minute or two than have my temps hit the 220's or something.
Old May 31, 2010 | 02:27 AM
Erick161's Avatar
Hmm, thats an old trick that still works.
I actually turned on my A/C and blasted the ice cold air My temps dropped into the 180s, and i was icy cold waiting in line to race.
Old May 31, 2010 | 02:59 AM
SPLREDLINE's Avatar
Ditto^^^^^^^^^^^ I live in the desert and the air con. trick works for me.
Old May 31, 2010 | 05:17 PM
skatin_boarding's Avatar
I just have my rad. fans kick in at an earlier temp with hptuners.
BLAZIN07SS's Avatar
I'm too JDM for you
me too. car rarely gets over 174*
Old Jun 1, 2010 | 12:58 AM
terry11's Avatar
my fans run constantly
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
