Running lean
Old Mar 3, 2009 | 12:12 PM
06SS ALL DAY's Avatar
are you stock, if not what mods? were you dyno'd in the summer?
Old Mar 3, 2009 | 12:16 PM
SmokinSamSC06's Avatar
Mine just went away thise morning and gas mileage is back to normal! THANK GOD!
Old Mar 3, 2009 | 06:42 PM
hossdeuce's Avatar
Originally Posted by D4u2s0t
no prob.
mmmkay tried shifting higher.. same thing and when the rpms drop after the shift.. its above 2k rpms... plenty of room to keep the car from stalling..
its not a clunk stall noise... the pedal is just non responsive for a second..
for instance: say im driving on the freeway and im in 5th gear at 65 mph. i let off the gas as a car in front of me starts to slow. i downshift to 4th (making rpms higher) and once i push back on the gas, it bogs and then jerks forward.. i dont understand... im going to try tightening all of my connections to see if there are any leaks...
its not an rpm factor. its all something with the motor choking on too much air
Old Mar 3, 2009 | 06:52 PM
rcorona8's Avatar
stupid question? what do you guys mean by running lean? thanks, i know, i know.
Old Mar 3, 2009 | 07:05 PM
hossdeuce's Avatar
it means the motor isnt getting the amount of fuel it needs..
the air to fuel ratio (afr) has more air in it then fuel
although the car still runs, the less fuel in the motor means the hotter it will get and more power if its not toooooo lean.
more fuel- cooler, but the car could lose power...
make sense?
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
