Safe rev limit on stock valve springs?
I seem to be finding most people saying 7,000 when I searched, but the opinions range from 6,500 (stock) to 7,400 being the point which you can go to without getting valve float.
Thoughts??
Thoughts??
i would say less than that depending on which numbers gm used. if they really fail at 7800rpm but gm is being conservative and said 7500rpm you should be ok. but i wouldnt run them at 7400rpm if theyre supposed to really fail at 7500m
Originally Posted by M-Dub
I'm sure they feel 7k is okay, since they raise it from 6500 to 7000 with Stage II! I wouldn't run 8k if the fail limit is 7500-7800! But that is my opinion!
Originally Posted by 06blackg85ss
I heard the stock block is balanced to a good 8800 or so rpm.... anyone research that? cause once I do cams and springs next month I was lookin to bump it up to 8000-8200 rpm
I would check the build book for the ecotec I think they have some info on it. The 300 HP LSJ build up replaces the springs and balance shafts. They replace the shafts because the rob HP from the engine.
Like I said on my dyno sheet the car is still climbing and then holds peak power from 6800-7000. I'm not sure when it would drop off but I think around 7,200 with the stock camshaft size you would start to see a drop off that peak.
I just have to change my injectors, swap my pulley, and get it tuned.
I have the JBP Stage 2 cams, and complete Bates valve train. (Check SIG)
I'll tune to about 8000RPM limit.
I know my cam's are making seroious power on the top end, and have alot more to go.
but a tune can only say for sure.
Originally Posted by rnjmur
I haven't been able to find any information on the rev limit for the neutral balance shafts. From what I can deduce, they should be good to somewhere around 8000 RPM.
Wop
DANRICKARD
Oct 1, 2015 12:08 AM
