what pully size = what amount of boost
Old Aug 17, 2006 | 06:45 PM
BlueSSupercharged's Avatar
i was looking at the zzp 2.85 or the 2.7 pully for my car but i would like to how much boost i would see with each of these pullies? also if i buy the gm stage two replacement belt would it work on ether of these pullies or would i have to get an adjustable tensioner?
Old Aug 17, 2006 | 08:25 PM
distillion's Avatar
i have the zzp 2.85 runnin with the stage 2 belt, no slip, the 2.7 from what i hear the belt should be ok too.
Old Aug 17, 2006 | 11:48 PM
OBSSSD's Avatar
I'm running the Billetflow 2.7" with 42lb injectors. I'm seeing 17.5psi with the car all stock. Once I get the K&N intake I have put on and then port the throttle body and blower I'm expectiong 19-20psi. I'm very happy with my pulley size - don't go smaller than a 2.7 IMO...
Old Aug 18, 2006 | 12:15 AM
distillion's Avatar
did you need the idler or you put it on just incase the belt slipped?
also did you have to shave the braket the idler pulley fits on?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
