Safe rev limit on stock valve springs?
Old Aug 16, 2006 | 02:25 PM
OBSSSD's Avatar
I seem to be finding most people saying 7,000 when I searched, but the opinions range from 6,500 (stock) to 7,400 being the point which you can go to without getting valve float.
Thoughts??
Old Aug 16, 2006 | 02:34 PM
rnjmur's Avatar
GM specs say the failure point for valves is at 7500 RPM. I would say that the max safe you would probably want to go would be 7400.
Old Aug 16, 2006 | 02:38 PM
Kahless's Avatar
i would say less than that depending on which numbers gm used. if they really fail at 7800rpm but gm is being conservative and said 7500rpm you should be ok. but i wouldnt run them at 7400rpm if theyre supposed to really fail at 7500m
Old Aug 16, 2006 | 02:39 PM
06blackg85ss's Avatar
I'm runnin 7400 but I don't usually shift that high.
Old Aug 16, 2006 | 02:55 PM
distillion's Avatar
id stay with 7 grand.
Old Aug 16, 2006 | 03:59 PM
korax123's Avatar
Im at 7200 but onl changed it yesterday. And won't see that high again until the track.
Old Aug 16, 2006 | 04:27 PM
Halfcent's Avatar
I'm old school
If it helps, another limiting factor on the engine rev are the balance shafts. They are not designed to run over the stock limit. I don't even know what a safe amount over 6500 would be.
Old Aug 16, 2006 | 04:33 PM
srt-killer's Avatar
When you do take it up to 74k do you feel any power loss or does the car keep gaining power?
Old Aug 16, 2006 | 04:54 PM
player_1's Avatar
how good do you think the balance shafts are.
I'm bumping my limiter to 8k.
Old Aug 16, 2006 | 04:59 PM
M-Dub's Avatar
I'm sure they feel 7k is okay, since they raise it from 6500 to 7000 with Stage II! I wouldn't run 8k if the fail limit is 7500-7800! But that is my opinion!
Old Aug 16, 2006 | 05:12 PM
OBSSSD's Avatar
That's what I was thinking - if they raise the limit with a stage reflash then they obviously feel that is near close to as safe as the 6500 limit. Otherwise, why would they risk bent valves and having to pull the head off a car still under warranty? I'm running 7,000 now, but thinking about running 7,400 in first and maybe 7,200 in second so I can shift it right at 7,000. The car keeps making more power and is still peaking when it hits the limiter at 7,000 now
Old Aug 16, 2006 | 05:21 PM
distillion's Avatar
if anything id go 7200 or 7300 but id always shift at 7, just so i dont run the risk of bouncing of the red line.
Old Aug 16, 2006 | 05:48 PM
zinner's Avatar
Moderator Alumni
I run 7100.
I know some people do 7400 with the stock valve train.
If GM is warrentying 7000 with stage 1 I would say 7k is a safe level.
I heard the stock block is balanced to a good 8800 or so rpm.... anyone research that? cause once I do cams and springs next month I was lookin to bump it up to 8000-8200 rpm
Old Aug 16, 2006 | 05:51 PM
zinner's Avatar
Moderator Alumni
I would check the build book for the ecotec I think they have some info on it. The 300 HP LSJ build up replaces the springs and balance shafts. They replace the shafts because the rob HP from the engine.
Old Aug 16, 2006 | 05:52 PM
Blown 4-banger's Avatar
Do the cams even support power up that high!?!? It seems like you would need a pretty serious set of cams to accually make power up to 8k!
Old Aug 16, 2006 | 05:53 PM
thats why the stockers are comin out...
Old Aug 16, 2006 | 05:59 PM
OBSSSD's Avatar
Like I said on my dyno sheet the car is still climbing and then holds peak power from 6800-7000. I'm not sure when it would drop off but I think around 7,200 with the stock camshaft size you would start to see a drop off that peak.
Old Aug 16, 2006 | 06:10 PM
player_1's Avatar
thats exactly what I did.
I just have to change my injectors, swap my pulley, and get it tuned.
I have the JBP Stage 2 cams, and complete Bates valve train. (Check SIG)
I'll tune to about 8000RPM limit.
I know my cam's are making seroious power on the top end, and have alot more to go.
but a tune can only say for sure.
Old Aug 16, 2006 | 06:46 PM
definatley keep me posted on that setup... thats what I'll be doin next month
Old Aug 17, 2006 | 10:38 AM
rnjmur's Avatar
I haven't been able to find any information on the rev limit for the neutral balance shafts. From what I can deduce, they should be good to somewhere around 8000 RPM.
Old Aug 17, 2006 | 10:44 AM
SS_SC_Cobalt's Avatar
straight from GMPD, 7200 is safe but they recommend strongly putting in bates springs and gm neutral balance shafts.....
Old Aug 17, 2006 | 01:06 PM
WopOnTour's Avatar
The GMPD neutral shafts have been safely revved to over 10,000 RPM. That's why they exist, unlike the stockers they are perfectly balanced- hence "neutral".
Wop
Old Aug 18, 2006 | 12:02 AM
OBSSSD's Avatar
How much $$$ and time to install are we looking at here?
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
