SC boost?
Old Aug 1, 2012 | 04:54 PM
  #51
07LSJ's Avatar
i thought lsj piston rings split at 305hp... as designed from factory? as i have seen in person anyone who breeches 300 hp, the rings split...
dam we have a couple lsj-t here all well above that and havent heard of any piston ring problems.
Old Aug 1, 2012 | 04:56 PM
  #52
Whitnith's Avatar
Not even turbo swapped...
Plenty of TVS ones are over 300...
Old Aug 1, 2012 | 04:57 PM
  #53
carstedt's Avatar
i was well abve 305 and mine never had a problem lol
Old Aug 1, 2012 | 05:00 PM
  #54
jrmotosports 88's Avatar
ok then..... it was just a question.... to be honest i have heard it many times.... maybe luck is on their side.... 1 small example is bluecobalt99... when he went tvs....
Old Aug 1, 2012 | 05:04 PM
  #55
carstedt's Avatar
ya idk maybe his were jus on their way out..im TVS and i was way over 305 on stock rings
Old Aug 1, 2012 | 05:07 PM
  #56
jacream_booSSted's Avatar
what technically would happen to the rings? just fracture from the force??
Old Aug 1, 2012 | 05:13 PM
  #57
maybe its not the rings but it could be the head of the pistons themselves, they crack due to pressure.... thus why we have diamond coated pistons available..... if i remember correct it was why they developed them..... the funny thing was he didnt even realize it was the problem until he torn the motor down.... all he knew that something wasnt quite right with the amount of power he should have had....
Old Aug 1, 2012 | 05:32 PM
  #58
carstedt's Avatar
idt its the pistons either....alot of us have been over 305 with no issues..im thinkin his internals may hav been on their way out the door
Old Aug 1, 2012 | 05:48 PM
  #59
yeah, not too many performance cars would have parts designed to break at only 100 more horsepower, or designed to break at all. but yeah who knows, maybe he was a special situation or like carstedt said, just had been on the way out already
Old Aug 1, 2012 | 07:47 PM
  #60
advise's Avatar
i made 328 no problems here
Old Aug 2, 2012 | 11:07 AM
  #61
ok so i did a small amount of research.... i also talked to a fellow member on this site who is lil more knowledge.... what gm performance division found about the stock pistons when producing 300+ hp is that they do crack.... even in this engine build article they are saying when planning to produce over 300 hp you should change the pistons.... points 7 thru 11.... if you ask me if this problem hasnt happen to you and your producing 300+ then touch wood and thank god.... your a lucky person....
http://www.gmperformancedivision.com.../23/ecotec.pdf
more literature for you page 101 it starts
http://www.gmperformancedivision.com...SJ_Chap5&6.pdf
i am sure with a lil more research i can find the actual article i have read and others i know have read....
Old Aug 2, 2012 | 04:28 PM
  #62
glad LNF's are okay
Old Aug 2, 2012 | 04:44 PM
  #63
Originally Posted by jacream_booSSted
glad LNF's are okay
they have their issues too.... lol
Old Aug 2, 2012 | 07:46 PM
  #64
well aware, lol but so does every engine/car, so it's whatever lol
Old Aug 3, 2012 | 10:30 AM
  #65
zrated89's Avatar
i will say when i was on my stock motor tvs street tune was 352whp. Went 12.4@114 pump gas i would pull lnfs badly with the same or more boost level. I seen about 22lbs. the powerband of the lsj is continuous where the lnfs is short bursts of power. When i was on my m62 at 18psi i would pull lnfs as well. now my race tune there was no contest.
Old Aug 3, 2012 | 11:01 AM
  #66
mrbelvedere's Avatar
your being overly dramatic over nothing the reliability comes from the tune running good fuel and meth or e and not beating the immortal **** out of your car on a constant basis even forged slugs wont take that
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
