shaky boost needle
Old Dec 7, 2010 | 10:32 PM
startingline05's Avatar
shaky boost needle
this ever happen to anyone before? normally ive been boosting around 25 psi. now i get about 23 and the boost needle gets very shaky when i get on it real hard which isnt normal. this happened after i took my manifold off to fix my endplate. i even took it all back off and put it back on again to see if i did anything wrong but its still doing the same thing
Old Dec 7, 2010 | 10:38 PM
Bl4des's Avatar
what do you have done to be boosting so much
and what kind of boost gauge do you have the ss/sc gauge only goes to 20
Old Dec 8, 2010 | 12:46 AM
tvs with a 2.8, and its a mechanical boost gauge that goes to 30psi
Old Dec 8, 2010 | 12:56 AM
mrbelvedere's Avatar
uh belt slip
Old Dec 8, 2010 | 01:00 AM
GM COBALT SC SS's Avatar
i think its normal for mechainical gauges to do this. my buddys srt4 did this also.
Old Dec 8, 2010 | 08:31 AM
no it isent normal
Old Dec 8, 2010 | 08:55 AM
RoadconeTuning's Avatar
gauge has gone out most likely. my friends stock gauge in his SRT-4 would do this... it also read that he was spiking high enough to WRAP the guage... put in a good aftermarket autometer gauge and it was fine after that..
Old Dec 8, 2010 | 09:16 AM
laser_racer's Avatar
It's not a electrical gauge it's mechanical so that means it works directly off the manifold. Bet that sounds stupid. You might have a boost leak now since you removed the manifold and put it back on. Do you have stock exhaust system on that car?
Old Dec 8, 2010 | 03:14 PM
my bad on the misinformation. i have been in two srt4s that had a similar problem so i figured it was normal.
Old Dec 8, 2010 | 03:28 PM
AjSS's Avatar
When I first put in my mechanical gauge it did the same thing, make sure everything is tight, seems like its caused from the higher pressure, so its not a heavy leak, probably a clamp that can't hold that much and needs to be tightened. After fixing a vacuum line clamp, my problem was fixed.
Old Dec 8, 2010 | 04:12 PM
now that u mention it. i dont remember clamping the boost line that goes onto the manifold lol
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
