Shifter Question
Old May 30, 2007 | 05:18 PM
an0malous's Avatar
finding 5th with aftermarket shifters has nothing to do with the shifter.
and everything to do with the install.
if you adjust your cables properly any short shifter will feel exactly like all stock shifts.
just shorter and firmer
Old May 30, 2007 | 05:32 PM
ecotecon18s's Avatar
I use the reverse lockout to find 5th...the way the cables are adjusted, the RLO (down) stops the shifter from going past the 5th gear slot...so its just over, bang, up. Now i've finally gotten used to the placement of Number 5, so its not so hard to just swing it over now. B&M def. takes some getting used to, but it def. makes a difference...'specially on the 1-2 shift...
Old May 30, 2007 | 05:38 PM
Johnboy12358's Avatar
I agree, my install took about 45 minutes of clip, shift, ****... change, clip, shift, dammit.... clip, shift, sweet!
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
