Show me the light
Old Sep 12, 2008 | 10:21 AM
TheSandMan's Avatar
Show me the light
ok so my warranty is finished its kinda a good thing but still a bad thing at the same time. any way my next step is going to be a cooling mod most likely H/E, still thinking about water/meth who knows. Any way my question is after the h/e i want to go stage two since i dont have to worry about the warranty any more what is the best way to go about doing this. also is stage 2 what i should be doing or should i move up.
Old Sep 12, 2008 | 10:23 AM
flash13brandon's Avatar
you should definitely move up to custom setup. Read my thread like one or two down and lemme know if you have a question.
Old Sep 12, 2008 | 10:27 AM
TheSandMan's Avatar
ok so how do i gt this custom tune i dont really have any shops around here that can tune my car for me and as far as all the upgrades i think i can do them my self. but who do i go to for the tune.
Old Sep 12, 2008 | 10:28 AM
falke401's Avatar
Wickedss in dayton tunes.
Old Sep 12, 2008 | 10:48 AM
TheSandMan's Avatar
so where would you guys say i should buy the parts by parts i mean injectors, belt, pulley what else am i missing please let me know and where should i get it from since the dealer is crazy expensive.
Old Sep 12, 2008 | 10:52 AM
ralliartist's Avatar
pulley from smoothflowpullies.com
you can fine injectors used in the classifieds section on this forum
belt from cobalt addiciton.
do you have any mods right now?
Last edited by ralliartist; Sep 12, 2008 at 10:52 AM. Reason: Automerged Doublepost
Old Sep 12, 2008 | 10:53 AM
TheSandMan's Avatar
the only thing i have is an Injen CAI, ok so i pretty much need all the information i can get i have no idea what kind of custom setup i should run so treat my car like you would yours what would you do. what size pulley, and injectors should i use.
Old Sep 12, 2008 | 11:09 AM
I wouldn't even do a pulley yet. I'd get a set of 42lb injectors, get a new front mounted heat exchanger, get rid of that crappy filler neck for your intercooler system and replace it with a reservoir(hatrickstu's cooling mod if you do a search), then I'd get a header and dp, throw water/meth injection on there, and get a custom tune.
Then later, once you get used to that much power, add a pulley that is sized to your driving style and how much you rev the car. You don't want to overspin the blower.
Reason I'd wait on the pulley is because you want to solve all your heat issues early, so that when you do throw on a pulley, you won't have major heat issues and possibly blow the car up from beating on it too much.
I promise you'll trap over 100mph in the quarter easy with all those mods well before you do a pulley swap.
Last edited by ralliartist; Sep 12, 2008 at 11:09 AM. Reason: Automerged Doublepost
Old Sep 12, 2008 | 11:13 AM
TheSandMan's Avatar
so my next steps is the h/e, 42lbs injectors, header and dp, then water/meth. where if i get these mods in this order will i need the tune just for the injectors or for the header and dp as well? after all this then move for a smaller pulley if i still feel the need for one.
Old Sep 12, 2008 | 11:20 AM
light'bolt's Avatar
oh I thought you were talking about me.... j/k sorry
anyway, the injectors require a tune, the H/E, header and dp don't require a tune.
Old Sep 12, 2008 | 11:23 AM
you'll need a tune for the injectors for sure. If you get a mild tune, then you can add the header and dp and when you put the meth on, then get another tune.
Old Sep 12, 2008 | 12:30 PM
TheSandMan's Avatar
should i get exhaust also or is my stock going to work fine with a dp and header?
Old Sep 12, 2008 | 12:35 PM
You will see better gains with full exhaust
Old Sep 12, 2008 | 12:43 PM
Better gains yes, is it worth the money? probably not. The header and downpipe will provide plenty of gains on the exhaust side.
Old Sep 12, 2008 | 12:48 PM
TheSandMan's Avatar
Really thanks that will save me some money then, thanks alot for all your help you guys are great at answering all my questions. First things first im going to be following flash13brandon's guide on the h/e then ill move on to continue with my lest. Thanks again guys for the help.
Old Sep 12, 2008 | 12:54 PM
WOOHOO! someone is using my how-to
Old Sep 12, 2008 | 12:57 PM
TheSandMan's Avatar
lol hell yea man i read through the entire thing and i like what i saw it works great and its cheap i mean you cant go wrong, but i read something about there being two different size h/e what one do you think i should get?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
