smaller pulley
Old Mar 17, 2010 | 09:40 AM
  #51
Jazer's Avatar
Originally Posted by 05Blackss.sc
well before i get a smaller pulley im going to do some cooling upgrades first and i would get it tuned the day i put it on. but def. cooling first im not going to be retarded and throw a 2.6 on a 3.0 pulley tune. clearly not going to be good for the car
Yeah, thats the way to do it.
I mean If 'you' were to start out with a stage 2 tune, and modify it for the car once its pullied down, then thats totally different.. but not making the tune specific for the vehicle as it sits, is a disaster waiting to happen.
Old Mar 17, 2010 | 09:54 AM
  #52
05Blackss.sc's Avatar
yeah im not that dumb lol and plus a colder running car is always better even if your just looking for reliability and not so much on performance
Old Mar 17, 2010 | 11:52 AM
  #53
ItalianJoe1's Avatar
Originally Posted by Jazer
Stock tune? This is a very bad idea. Too much heat can be your enemy, so is a bad tune for what the car is running.
I wouldnt even run GMs stage 2 tune with a smaller pulley than what it was meant for... aka, 3.0.
You may have been lucky, but that isn't good advice to give out..
Maybe I wasn't clear, it was a stock Stage 2 tune. I also know the difference between pushing the car and abusing it. Many on here don't.
Old Mar 17, 2010 | 12:01 PM
  #54
Black_Mamba's Avatar
Originally Posted by roadrage06
too many people think the only thing they need to compensate for is the engine -- everyone overlooks that expensive little item that makes all that power to begin with -- the supercharger!
do a little research, below a 2.8 you overspin the blower and you're not really making any more power efficiently. If you want more than a 2.8 you need to get a bigger blower or go turbo.
Agreed. If ur thinking about doing anything below a 2.8 just scrap ur pulley ideas all together and get the TVS.
Old Mar 17, 2010 | 12:32 PM
  #55
Originally Posted by Black_Mamba
Agreed. If ur thinking about doing anything below a 2.8 just scrap ur pulley ideas all together and get the SMG Twincharge.
fixed
Old Mar 17, 2010 | 12:33 PM
  #56
Old Mar 17, 2010 | 12:45 PM
  #57
Jazer's Avatar
Even still.. the stage 2 tune is made for a 3.07 pulley, and running a 2.8 is not the same.. not responsible IMO. Atleast it worked for you. Probably because GMs tune is on the conservative side.
Old Mar 17, 2010 | 08:56 PM
  #58
Durtyss's Avatar
I'm going to a 2.8 , I will have meth and a aftermarket h/e. Will that be enough for cooling?
Old Mar 18, 2010 | 08:08 AM
  #59
i think you should get one step cooler spark plugs. they r highly suggested on other sites
Old Mar 18, 2010 | 08:36 AM
  #60
I didn't say it was the best setup or anything, I said it's possible and it is reasonably safe. I did it with a 50 shot on top of it for a while with no problems. Obviously you should always keep the car tuned for the mods it has to be the safest and most powerful, but dropping a pulley size before you tune is not certain death.
I actually knew a guy locally who was running a 2.8" pulley and an intake on an otherwise bone stock car. Dunno how it held up for as long as it did, but it never blew up. That shouldn't have lasted IMO.
Old Mar 18, 2010 | 09:50 AM
  #61
^^agreed i knew a guy who but a 2.6 on a stock car and it blew up in 3 days...voids warranty's too
Old Mar 18, 2010 | 10:00 AM
  #62
Xephirothx's Avatar
Way to make me paranoid guys.. :/ lol
Old Mar 18, 2010 | 05:19 PM
  #63
You'll be fine bro. I'd be more concerned that your tune is basically setup for meth and you don't have meth...
Swing by when you get a chance, i'm home a lot now because i'm not working.
Old Mar 19, 2010 | 08:06 AM
  #64
all about tune and how cold your car is running for ur mods
Old Mar 19, 2010 | 08:41 PM
  #65
red06SC's Avatar
funny that everyone spouts off about 2.5s, 2.6s, and 2.7s...but one of the fastest M62 cars on this site had a 2.85..
A lot of people here need to learn how to make efficient power, and transfer it to the ground efficiently instead of just throwing more air and fuel at the situation.
Old Mar 20, 2010 | 11:55 AM
  #66
Jazer's Avatar
Bingo.
Old Mar 22, 2010 | 08:18 AM
  #67
agreed
Old Mar 22, 2010 | 10:08 AM
  #68
ebristol's Avatar
Huh?
LSJ, MODDED,STILL USING THE STOCK SUPERCHARGER(NO OTHER POWER ADDERS)
1.)OneCOLDBIZL272, 12.235@119mph, 2.101 60', I/H/DP/CD/E/2.5/PB/WI/TB/PH/IM/CM/C/SM/BE/T/DS Timeslip PIC
2.)Ryan@zzp, 12.3272@114.32, 1.802 60', I/H/E/DP/CM/2.6"/DS/SM/T/BE Timeslip VID *LNF TRANS (longer gearing than stock)
3.)hatrickstu,12.756@108.92 w/1.936 60' 2.85/I/H/DP/CD/E/T/CM/WR/SM/DR's Timeslip Vid
4.)DWK5150,12.84@110.53 w/2.04 60',I/PB/DP/E/2.5"/CM/T/DR
5.)Fast06SS,12.86@109.13 w/1.93 60', I/E/CD/T/2.5"/DR
6.)OntarioKev, 13.039@111.85 w/2.095 60', I/H/DP/E/CM/WI/DS/SM/2.7/T PIC Timeslips
7.)CobaltSS1,13.18@108.05 w/2.11 60',I/GMH/E/2.6"/T/ST
8.)Enufpwr,13.20@106.13 w/2.03 60', I/E/T/2.5"/CD/DP/DR's
9.)thc, 13.215@106.77 w/2.013 60', HW/3"/I/H/CD/DP/E/CM/T/SM/DR Timeslip PIC
10.)ralliartist,13.23@104.08 w/1.95 60',A/CM/WI/H/DP/CD/E/IM/2.9"/T/SM/DSTimeslip VID
7 out of the top 8 use a 2.7" pulley or smaller.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
