Smg twincharged rebuild project
screw the startup, id like to see it make nice numbers and then stay together for a period of time. then if i still have the car i might consider it who knows
thanks man, thats just being used to hold the radiator in place for the time
stage 2 pulley
Car is slowly coming together, sort of held up trying to get ahold of some motor mount bolts and upper tranny mount bolts as well as this fitting for the clutch line to the transmission. Dealership said it should be in by wednesday. Above is a picture of the valve cover painted.
Parts should be in tomorrow and car may be ready to have at least 1 day at the track before they close for the year. Ordered a pair of these to help out..
Uploaded with ImageShack.us
Still waiting on a seal. Everything else is in but this one seal that is almost impossible to find.
In the picture Above shows the fitting on the transmission, you can see a little bit of piece of tubing out of that rubber boot that is attached to the transmission. That piece of tubing is suppose to be covered by this seal that we are having a nightmare trying to find.
Below is a picture of the fitting that attaches to the above picture. This fitting connects the clutch line to the transmission. Without the seal it will just shoot oil everywhere.
We ordered a couple more parts hoping to have the seal we need but that won’t be in until Friday at the earliest.
If anyone knows exactly where to get this seal perhaps somewhere local so I can get it together sooner that would be awesome. Otherwise Ill post back once we get that piece.
...unless I can borrow yours! haha
Thanks, any idea what to search for on there site? I am browsing around transmission parts but cant find it. Also, if you sell anything that you would recommend for my build thats not already on my list let me know! Im pretty much going all out on this car haha
I suggest spherical control arm bushings, his rear swaybar, his harness bar, anything John sells.
Ask Fred about the CAB install on my car lol.
Johns stuff is top notch, greatly priced, and the differences each part provides is night and day over stock.
good to hear! whats the plan? let it run for a bit and put miles on it before turbo install or just start and make sure motor build is ok before adding turbo or what?
glad to hear shes another step closer.
You bet, the car will be all dyno’d before I even pick it up. I do have a video of the start-up right now but not really worth posting... just a rough idling engine and a bunch of smoke from the exhaust haha.
