Smg twincharged rebuild project
Does any1 have experience with the return style fuel system? (Ottp) SMG told me about this before I even got my car back.. but anywhere around a 1/4 of a tank of gas or less if you go wot the car will run very lean and fall on its ass. Is anyone familiar with this and possible solutions?
Thanks for the info guy, i passed the info and should be getting that checked out soon. Now back to the BOV, I know some of you told me to ditch the HKS and go with Tial.. which I most likely plan on doing. Anyways I mentioned it to Fred @ SMG and he said the flutter is completely normal for that BOV as some of you already mentioned but he said it has no negative effect on the turbo. He said BOV flutter and turbo flutter are 2 different things. He said if the turbo were to flutter Id hear the difference. So today I drive the car a little and throw the gopro on there. After watching the video I heard what may be turbo flutter. Not the best video but you should be able to hear what Im talking about. Its a noise Id never hear from the drivers seat considering how loud the exhaust is and the turbo being where its at. Just wanted to post the video clip to see if you think that may be flutter Im hearing.
Link to clip: Turbo Flutter? on Vimeo
meh bov should never flutter either imo if it does something isn't right. sounds like compressor surge, your turbo is rear mounted, right? shouldn't be picking up the bov with the cam that far back anyways which would further make me come to that conclusion. i had bad compressor surge with my greddy type rs lol and that sounds pretty much just like it.
Should I go with the 8psi spring or the 10psi spring? I know they say 8psi is intended for the LSJ but I wasn’t sure if anything changes being as custom as I am with this car.
The BOV is located below the drivers side headlight. I asked Fred a few days ago about if anything was tied into the vacuum line for the BOV and he said it wasn't. He said the reason why the BOV itself didn't flutter before was because originally he had them tied in with others. Ill have to take my headlight out tomorrow after work to confirm this. Im sure its pretty straight forward to see if its not tied in with other components right?
The only thing I know that he tapped into the IM was meth injection. He may have tapped the vacuum line there though.
Will do, thanks!
Will do, thanks!
Last edited by KangolRiot; Feb 26, 2012 at 10:09 PM. Reason: Automerged Doublepost
Found a new problem with my car... When I floor it in 2nd gear or even 3rd gear at times my tires keep spinning! I have no idea what could be causing this. Any ideas???!
FINALLY got an inspection sticker, he had to mess with the tune or something like that. He said he also fixed the fuel issue which was caused by the walbro fuel pump. He installed a new1 and said it is now all set
some blowoffs have 2 nipples on them for vacuum lines. 1 above and below the spring I think. I cant remember off the top of my head but depending on the psi maybe you would have either just the top line hooked up or both. Mine fluttered a lot cus I had both lines connected until someone noticed and now it does the crisp blow off.
Some one can chime in if they know what I'm talking about.
z28addiction
Sep 28, 2015 12:03 AM
