So many choices so little time...
Old Jul 18, 2008 | 06:49 PM
Tazmanian_Dvl's Avatar
Cool So many choices so little time...Aeroforce Interceptor...
To all of you who have Aeroforce Interceptors...What do you normally set your displays to? I am going to be setting the one gauge to IAT1 and IAT2. However I"m not sure what to set the other one to. Any thoughts or ideas? Here's the list...
* RPM
* MPH
* Intake Air Temperature pre intercooler
* Intake Air Temperature post Intercooler *
* Mass Air Flow Sensor Frequency *
* Mass Air Flow Sensor (lb/min.)
* Engine Coolant Temperature
* Injector Pulse Width
* Long Term Fuel Trim
* Short Term Fuel Trim
* O2 Sensor Voltage
* Manifold Pressure in PSI (Boost pressure)
* Supercharger Inlet Pressure *
* Ignition Advance
* Knock Retard *
* Engine Run Time
* Battery Voltage
* Throttle Position Percentage
* Engine Load
* Instantaneous fuel economy
* Horsepower
* Analog input #1
* Analog input #2
Any thoughts would be greatly appreciated! Thanks!!!
Old Jul 18, 2008 | 06:53 PM
an0malous's Avatar
IAT2
knock retard.
rarely moves from those.
Old Jul 18, 2008 | 09:28 PM
theneelster's Avatar
Iat2
MPG
Sometimes I run MPG and MPH so I can disregard the center cluster (redline).
As far as the other settings pulse width is useless unless you memorize the conversion by rpm (which I can't); boost/vac is useless because you already have a boost gauge; horsepower would be good but you need to adjust it for your car (ie dyno).
Old Jul 18, 2008 | 10:27 PM
bump...bump...bump it up
PS i have IAT1 and IAT2 on one gauge i just need to know what to set the other one on...
which knock sensor does everyone use for their knock readings?
Also why does my boost read -.05 when the car is off? Any thoughts?
Last edited by Tazmanian_Dvl; Jul 18, 2008 at 10:27 PM. Reason: Automerged Doublepost
06blackg85ss
83
Jan 18, 2017 04:35 AM
jas09ss
Sep 26, 2015 01:06 PM
ATOMbomb
Sep 11, 2015 10:48 AM
StupidSlowCRX
Aug 17, 2005 09:03 PM
