so possible cooling option
Old Jan 20, 2010 | 11:09 PM
joshcsepegi's Avatar
Lightbulb so possible cooling option
so i found this shell and tube heat exchanger
http://www.exergyllc.com/products_shelltube23.php
so what if you pumped nitrous in this on the one side or co2 for that matter
does nitrous or co2 get higher than 1000 psi?
Old Jan 20, 2010 | 11:22 PM
chevysssc's Avatar
not if released into atmosphere. i would like to see iat2 temps before and after numbers.would be a cool addition to a cryo2 setup. whats the price?
Old Jan 21, 2010 | 02:15 AM
Omnigear's Avatar
no flow numbers for it?
dont need high pressure
we need high volume.
Old Jan 21, 2010 | 04:46 PM
red06SC's Avatar
I thought about doing a cry02 fuel rail setup inline with mine
too much investment for little gain
Old Jan 21, 2010 | 04:49 PM
ralliartist's Avatar
I'm not seeing how this would work. you want to lower heat, not pressure. I also think that all the possible cooling methods have been discovered at this point.
front mount heat exchanger that you can use in line with the stocker
ice box
dual pass opt b
single pass
killer chiller
cryo2
water/meth
Old Jan 21, 2010 | 05:49 PM
chevysssc's Avatar
ebay! payed $150 for 150ft +4ft line, spray bar, and intake bulb. i just got my interceptor so i havent tested it yet probably mont change much but it doest hurt.
Old Jan 21, 2010 | 05:52 PM
EXsoccer1921's Avatar
on this note. killer chiller is only good for dyno numbers. cause iirc you need your a/c on for it to work. well, drag strips don't allow you to run a/c while making a pass.
Old Jan 21, 2010 | 05:57 PM
utsadude's Avatar
Isn't this just like a Killer Chiller?
Old Jan 21, 2010 | 07:21 PM
red06SC's Avatar
I was looking more along the lines of using the fuel bar to quickly chill the blower coolant
Old Jan 21, 2010 | 07:51 PM
jazzyjames1371's Avatar
you could probably use it for a cheap knock off of the killer chiller if you could flow enough cooland through it. wouldnt be as efficeint though.
so this tube is like a heat exchanger in a tube. the top 2 fittings are independent of the fittings on the end.
my thought was this run the coolant just before the ic into this then the output into the ic. then apply co2 or no2 into the top ports. instant cooling.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 28, 2015 01:31 PM
