Spark plug gap for 2.8"
Old Nov 6, 2009 | 11:09 AM
Jn2's Avatar
Jn2
Like the title says, I'm running NGK 1 step colder plugs(heat range 6). What gap should I change them too? They are iridium, so I know I have to be careful when gapping them.
Mods:
2.8" pulley
60lb injectors
dual pass
frozenboost dual core h/e
knn intake
pacesetter header
modified lsj dp
Megan catback(oval muffler w/magnaflow tip)
ttr poly tranny bushings
ttr poly engine mount
working with vince on my tune, here's what he said:
"There are two things happening here.
1)****** It’s still too rich
2)****** The knock sensors are picking up noise the ECM thinks is spark knock and its sending the timing into the basement
#2 could be because of #1 though (if it is real knock).*"
I have double checked every wire, gasket and bolt. Mechanical it's all good to go. Just Need to figure this spark knock.
Old Nov 6, 2009 | 11:31 AM
Bl4des's Avatar
use copper plugs they work better but they need to be changed every oil change
Old Nov 6, 2009 | 12:53 PM
Jn2's Avatar
Jn2
We don't have a copper option, im a 2.2, I have looked and I can't find Cooper plugs.
Old Nov 6, 2009 | 01:06 PM
Illini_06SS's Avatar
2.8" pullies should be 0.035" I believe...
Old Nov 6, 2009 | 01:08 PM
D4u2s0t's Avatar
aren't the spark plugs interchangeable between models?
Old Nov 6, 2009 | 01:11 PM
ecotecturbo's Avatar
2.8 on a 2.2 thats a risky one.
Old Nov 6, 2009 | 02:02 PM
Jn2's Avatar
Jn2
K I'll try that. Thanks
sorta kinda. Same threading, but the threaded part is longer on mine than the lsj. What's the p# for 2 step colder copper plugs?
yeah, but no risk no reward
Old Nov 6, 2009 | 02:06 PM
mtbrent's Avatar
Are you running LFR6A-11 like alot of other boosted 2.2/2.4's? If so, those are copper plugs. Also, mine lasted 20k before i replaced as preventative maintenance.
edit: yea i can't read apparently as you said iridium in first post! Maybe switch to the coppers I mentioned then, which are also 6 heat range.
Old Nov 6, 2009 | 02:20 PM
Jn2's Avatar
Jn2
I'm running:
- LTR6IX-11
they r iridium. Ima swing by vatozone and pick up some copper ones when I get off work. Also got a new tune I got to try
Old Nov 6, 2009 | 03:03 PM
Omnigear's Avatar
the 2.2 in my hhr is deeper
the threads is hella long.
i still dont see no evidence
of changing the coppers every
oil change.
Old Nov 6, 2009 | 06:47 PM
Black SS/SC 06's Avatar
Mine are .032
Old Nov 6, 2009 | 07:46 PM
InfraRedline's Avatar
Mine are 0.032 as well
Old Nov 7, 2009 | 09:02 AM
JapEatr's Avatar
South Central *********
i also run .032, BRK7E Cu
JN2 how much timing are you runnng? Commanded vs. actual?
Do you have aggressive mounts that cause severe vibes? This can be picked up as knock
what is your A/F ratio say? 60s are pretty bad at getting choppy at idle.
Old Nov 7, 2009 | 11:21 AM
damien's Avatar
I've seen this first hand caused by poly mounts. Picked it up on an interceptor and verified with HPT.
Old Nov 7, 2009 | 01:15 PM
Jn2's Avatar
Jn2
Yes I do have all solid mounts. So that could be part of it. I recapped my spark plugs to .037...they were at .050 O_o factory falling from ngk...I couldn't find any heat range 7's yesterday. Not in my size, guess I have to order them. Also we did moretuning and my car is running a lot better. Getting 15psi on my 2.8...
16* of timing. Should I run more? I have no way to know iat2's either btw.
Old Nov 7, 2009 | 01:17 PM
advise's Avatar
yup mine are .032 also work well
Old Sep 16, 2018 | 01:58 AM
boostbalt's Avatar
I was having issues with any gap > .035 and boost blowout hesitation, 0.032 feels perfect for a 2.8" pulley. I'll stay at this gap from here out.
Steven Flit
Oct 27, 2009 09:43 PM
Rodimus_Prime
Feb 23, 2009 04:40 PM
Area47
Oct 26, 2007 09:07 PM
R&C_rallySS
Sep 7, 2007 02:34 PM
