Spark Plugs
Old Nov 22, 2010 | 11:15 AM
willdrew's Avatar
Spark Plugs
What spark plugs do u guys recommend? I have gm stage 2, intake, exhaust.
Old Nov 22, 2010 | 11:18 AM
icemaid's Avatar
Ngk brk7e
Old Nov 22, 2010 | 11:22 AM
willdrew's Avatar
What about NGK V-Power or NGK Iridium? And what colder step 1 or 2?
Old Nov 23, 2010 | 08:28 AM
willdrew's Avatar
bump more opinions
Old Nov 23, 2010 | 08:41 AM
Staged07SS's Avatar
Administrator
Administrator
If you need new plugs get Ngk brk7e.
If not, the stock plugs are perfectly fine for a GMS2 car.
Old Nov 23, 2010 | 08:52 AM
willdrew's Avatar
ok kool and does it matter if i go one step or 2 step colder
Old Nov 23, 2010 | 09:00 AM
Staged07SS's Avatar
Administrator
Administrator
You really do not need to drop a step with GMS2. The stock heat range is perfect for the application, but if you must switch the plugs one step cooler will be fine.
Old Dec 1, 2010 | 02:43 AM
PenguinPIE's Avatar
i got the NGK BRK7EIX right now with my Stage 3. What should I gap it at? I heard .031 to 0.035 but at the same time I found this old thread saying we can try up to 0.045 and we should also feel power increase with larger gap?
mine is gapped at 0.032 at the moment
Old Dec 1, 2010 | 05:55 AM
metalmedic's Avatar
this is prolly a dumb question but what's the benifit of a 1 or 2 step colder plug???
Old Dec 1, 2010 | 06:43 AM
jaygo7007's Avatar
in for answers
Old Dec 1, 2010 | 08:03 PM
metalmedic's Avatar
bump for some answers
Old Dec 1, 2010 | 11:35 PM
PenguinPIE's Avatar
colder plugs enable faster heat dissipation after they fire. they are good to have for modified engines to prevent pre-ignition because the combustion is hotter.
the rule of thumb is to go 1 step colder for every 75-100hp gained
somebody correct me if i'm wrong tho...
Old Dec 1, 2010 | 11:44 PM
SunburstSS's Avatar
Holly Shytttt...50' is the difference between ur IATs ur pump = bad or something lol
Old Dec 2, 2010 | 12:06 AM
Staged07SS's Avatar
Administrator
Administrator
You are correct.
Old Dec 2, 2010 | 12:50 AM
PenguinPIE's Avatar
haha yes, that was when my pump was dead. it is replaced under warranty now
btw could anyone answer my original question a few posts up?
Old Dec 2, 2010 | 12:57 AM
Leafydialupking's Avatar
The plugs run at a lower surface temp (when not sparking) making for one less hot spot in your combustion chamber to cause knock.
And for the gapping. I'm running at 0.032 with my crappier than your ignition and I have no spark break up under boost.
Old Dec 2, 2010 | 07:08 AM
Staged07SS's Avatar
Administrator
Administrator
When I was running the M62 and was straight GMS3 I ran the stock plugs at a 0.035" gap. Worked great until I switched blowers, and pullied down. I now run a 0.032" gap with 1-step colder plugs. I know some websites claim a 0.040-0.045" gap, but that is much too large for a blown car. You will def. experience spark blowout with a gap that large. You want the largest gap possible w/o spark blowout. I would try 0.035" if I were you.
Old Dec 2, 2010 | 01:33 PM
metalmedic's Avatar
well thanks for the info... and sry for the thread jack op....
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
