sparking BAD!!!!
Old Aug 8, 2008 | 01:06 PM
thatotherguy's Avatar
Originally Posted by Tazmanian_Dvl
haha I'd be arguing with GM about that one. I got them to cover my step brothers car even after it was out of warranty
I called 3 times and talked to different service guys and the all told me the same thing. where i take it its going to have to be towed. but i found the problem i think. the ground wire that goes to the start is on there but the little gold squar peice turns inside of its self so i guess it was tighten to much or something or it just finally broke.. i didnt tighten it or anything i was turning it with my hand and the peice inside turns.
Originally Posted by bolus
Pleases dont start touching metal tools to the starter and the loose wires without unhooking your battery.
I did unhook the battery..
Last edited by thatotherguy; Aug 8, 2008 at 01:06 PM. Reason: Automerged Doublepost
Old Aug 8, 2008 | 01:18 PM
Tazmanian_Dvl's Avatar
Call GM customer care. It's in the back of your owners manual...
Old Aug 8, 2008 | 01:54 PM
Ok i called and they said its not anything to with the power train warrenty. he said thats a wear item. so im screwed with the warrenty ****.
Im Looking on ebay and they has a few used lsj starters on there for 34 bucks, i can get a new one for 279 from gm. what do yall think would be better? new or used?
Last edited by thatotherguy; Aug 8, 2008 at 01:54 PM. Reason: Automerged Doublepost
Old Aug 8, 2008 | 02:03 PM
Do what you want dude. Seriously though you probably have an electrical problem not a starter problem. The lose wires should be an indicator. If your only experience with cars is bolting on a few mods then you're not experienced enough to diagnose an electrical problem on a car like this. **** I've built cars from the ground up and with all the computer controls and electrical stuff I'd be hesitant to **** with **** if I wasn't friends with guys that work at my local dealership. Honestly you are gonna be just replacing parts at this point until you find the problem. If you have the time and $$$ to guess at **** then by all means go a head but I would suggest a trusted mechanic...
Old Aug 8, 2008 | 02:08 PM
Let me ask you something, If it was the starter you think it would spark pretty bad?? Because something around the starter is sparking or maybe its the starter. But to me if the start was done it wouldnt spark or anything. I had a guy that built my engine look at it but it was day light outside and he said my starters toast. but we couldnt see any sparks. but lastnight i did see it because it was dark.
Old Aug 8, 2008 | 02:14 PM
If it's sparking there are bare wires somewhere grounding out...
Old Aug 8, 2008 | 02:15 PM
Ok ill go look around and see whats up and ill get back to ya and let you know if there are any wires touching
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Iceberg
Sep 29, 2015 12:33 PM
