spec -3 clutch
Old Oct 16, 2009 | 08:50 AM
ITMSilverSS/SC's Avatar
Exclamation spec -3 clutch
I need to know what parts come with the spec -3+ clutch when u buy it from a vendor ??? and is the stock flywheel aluminum or steel ???
Old Oct 16, 2009 | 10:19 AM
harryresh's Avatar
The stock flywheel is steel and weighs 19 lbs.. You can buy an aluminum flywheel w/ a steel center from ZZP for $309 that weighs 8.5 lbs.. You might wanna post this thread in the drivetrain section...
Old Oct 16, 2009 | 10:22 AM
Solidus Snake's Avatar
just the pressure plate and friction disk. you would need to buy the aligment tool and the release bearing yourself
Old Oct 16, 2009 | 11:23 AM
lsjwannabe's Avatar
Most spec kits come with the alignment tool.
Old Oct 16, 2009 | 12:21 PM
spec 3
any nuts, bolts, or washers that u need to install ? cause mine came just with pressure plate and clutch disc and alignment tool .. ???
Old Oct 16, 2009 | 12:44 PM
BCobaltSS's Avatar
flywheel bolts, presure plate bolts , throw out bearing and throw out bearing bolts
Old Oct 16, 2009 | 01:14 PM
spec 3
can u use the stock bolts ??
Old Oct 16, 2009 | 01:22 PM
Edubs's Avatar
Probably not. I'm sure they're TTY...
Old Oct 16, 2009 | 01:56 PM
spec 3
since i cant use the stock flywheel and pressure plate bolts...... were can i get the aftermarket ones that i need ????
Old Oct 19, 2009 | 12:25 PM
BCobaltSS's Avatar
Crate engine Depot
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
