ss sc 5psi
Old Mar 22, 2011 | 11:56 PM
chingo450r's Avatar
ss sc 5psi
Before anything im out of town working for a while and im on through my phone im pretty sure this has happened to someone and its posted here but its hard to search through this phone lol
Well anyways I made friends with another guy who has same year cobalt as me 06 SS SC with airbox mod and exhaust tip like me he's car is doing 10 psi mine only 5psi?? What could this be I never new stock was higher or em I normal? New with these ss
Old Mar 22, 2011 | 11:59 PM
Bl4des's Avatar
bypass valve stuck open
Old Mar 23, 2011 | 11:35 PM
chingo450r's Avatar
Where is this and how do I fix it? Is there a how to here
Old Mar 23, 2011 | 11:39 PM
Chevycobaltss3's Avatar
the black looking thing on the s.c the has the two hoses on it. the little arm that is on the bottom of it goes tot he butterfly on the sc so it lets air bypass the rotors of the sc so it dont create heat so much. Make sure the arm is all the way up since itll have vacuum in it. Also if you have more issues take the sc off and sand the bypass valve hole where the butterfly sits and sand it down so it wont get stuck
Old Mar 24, 2011 | 08:01 PM
chingo450r's Avatar
Just checked it it's good
Old Mar 24, 2011 | 08:50 PM
K then if ure cars not boosting correctly verify ure belt is not slipping. Ure solonoid isnt bad and veridfy ure ic pump is working look for boost leaks as well
Old Mar 24, 2011 | 11:56 PM
Bl4des's Avatar
you dont have cel?
etnies
Forced Induction
25
Dec 13, 2011 10:38 PM
ah665
53
Nov 4, 2011 12:13 AM
etnies
Forced Induction
Oct 6, 2011 08:50 AM
SCMitch
Aug 23, 2011 03:22 PM
